Like Tree5Likes
SC10 4x4 Thread
Old 04-26-2012 | 06:09 PM
  #22216
kingkole's Avatar
im running on a bigger loamy track with a 18 tooth on my 5.5 with 4 degrees timing and run like 140 degrees but run a 13-16 on indoor and it stays cold maybe 100 degrees
kingkole is offline
Old 04-26-2012 | 06:33 PM
  #22217
JEFFs SC10's Avatar
Who's racing this weekend?
I'm super broke but wanna run!! I want revenge for last time LOL
JEFFs SC10 is offline
Old 04-26-2012 | 07:04 PM
  #22218
IRM616's Avatar
I'll be racing at west coast raceway. Been working on my sc10 like crazy
IRM616 is offline
Old 04-26-2012 | 07:07 PM
  #22219
kjohnsiii's Avatar
I might make the trip down too.
kjohnsiii is offline
Old 04-26-2012 | 07:14 PM
  #22220
JEFFs SC10's Avatar
jealous!! I'd love to run there. love to run my buggy there. actually working on it now lol.
Old 04-26-2012 | 07:22 PM
  #22221
IRM616's Avatar
I'm racing my stock b4 and sc10 4x4....I've been trying to dial my truck but the rear is getting under the truck. That's been my main issue. I'm running yellow springs all around. Tried FT blue on rear and no help. Got the C hub and that helped but not as much as I like. I'm running zero spacers on inner ball stud (rear and front). I think if I can find that one thing my truck would be dialed. Work in progress...
IRM616 is offline
Old 04-26-2012 | 07:25 PM
  #22222
JEFFs SC10's Avatar
I have 4 mm under my rear stud on the tower. That should help alot.
first run 2mm then go up till it feels right.
Old 04-26-2012 | 07:26 PM
  #22223
vito's Avatar
how do the 4x4 run it the street?
vito is offline
Old 04-26-2012 | 07:38 PM
  #22224
boborc's Avatar
Has anyone tried those MIP Bypass1 shocks yet,curious if they work???and how well
boborc is offline
Old 04-26-2012 | 08:08 PM
  #22225
keddy's Avatar
Need help.
Can't get my kit shocks to stop leaking.
They leak out of the x-rings.
I've tried:
New cartrage with new seals
Green slime
TiN shafts.
All those items are currently new. I built the front shocks with 30wt bladder with zero rebound. After 5 pumps of the shock shaft, oil starts coming out at the seal.
I have no idea what else to try.
keddy is offline
Old 04-26-2012 | 08:19 PM
  #22226
JEFFs SC10's Avatar
did you try different o rings? they might be shot.
Old 04-26-2012 | 08:20 PM
  #22227
keddy's Avatar
Brand new ones came with the cartrage kit.
keddy is offline
Old 04-26-2012 | 08:48 PM
  #22228
WC posted a while back to shave 1mm off the x-ring housing. The little plastic piece that holds the x-rings in place. Probs about twenty pages back. Was going to try but so far mine aren't leaking...
jayrat is offline
Old 04-26-2012 | 08:53 PM
  #22229
Go AE's website and dowload the FT SC10 4x4 manual. AE added an additional o-ring ASC6469, which is the same o-ring used in the 2wd shock caps and other shocks, that goes between the shock cartridge body and the shock body.
Also, make certain the tapered side of the shock cartridge is pointed up as on page 24 of the FT manual and page 21 in the Team version. I also wait to tighten down the shock cartridge cap until after I've inserted the shock shaft. I turn the shock shaft as I'm inserting it so as to not "scrape" the threads past the x-rings, possibly damaging them.
Also, make certain you aren't damaging the shafts with pliers or something. I hold my shock shafts with diagonal side cutting wire cutters right above the top thread of the shaft when I'm threading on the shock rod end. Others use something to protect the shock shaft, like a cloth, to protect the shaft.
Steven
SBWheels2008 is offline
Old 04-26-2012 | 09:00 PM
  #22230
IRM616's Avatar
Okay. Thanks I'll work on that
IRM616 is offline
