SC10 4x4 Thread
If your looking at the ft upgrade package that includes the clutch basket it's a really good deal if you're still running the original slipper.
what is correct order of RcShox garodiscs with basket. Does the smallest go furthest in near gear box between spur and inner hub?
Selling my factory team $530 shipped artr with hobby wing esc used 3 times Tekin 550 6.5 used 3 times venom 4200mah saddle used more than 3 times aka wishbones used 3 times blue sc10 4x4 body the car runs great and only used 3 times on carpet twice and once on dirt pics can be requested by pm
Hey guys, I got a problem. I just got a Tekin Pro4 4000kv in my sc10 4wd and its is getting way hot with the gearing the tech support says to run. I started with a 15t pinion and the 62 spur. Run 5 laps and the motor was at 180, the LRP SXX TC was at 135. No boost at all. Went down to a 11t pinion and brang temps to 175, not a whole lot of difference. Need to get this set up going. any help will be appreciated.
Chuck
Chuck
What track is he running on? Is he just blasting up and down the street full throttle each way?
R/C Tech Elite Member
A while back, Wild Cherry wanted to compare the weight of my clutch basket with AE's new basket. Apples and oranges really. my scale only reads grams, and they weighed the same. However, I finally was able to machine some prototypes for the new slipper. Near as I can measure, they're half the weight of AE's.
Hope you do well with the new version of your slipper,.
Seems rather clear the new Ae VTS slipper performance sets a new standard for everyone to beat ...
mac
I never intended to make out your products are less than others or diss ....
Welcome it all and your input ...
Just built a new brace! Camo and much stiffer than the AE carbon one.
Pics:
Before anyone says anything, lets be honest how many of you have actually popped a ballcup and when you did what else did you break in that crash?
Okay have a wieght question, maybe WC can chime in.
Want to shave some weight of my truck, currently weighs in at 6lbs 8.5oz
rtr.
Does anyone know how much wieght the titanium turnbuckles will save?
Also I was positive that the TiN hingpins, and shock shafts are titanium with a coating, but can't find anything on AE's site that leads me to believe this. Are the titanium?
rtr.
Try aluminum screws. I believe the turnbuckles shave .2 oz. But don't listen to me on shaving weight lol (look at above pic, 5.5 oz added)
First time out w/ the FT
Finally got to go out and drive my new FT with the RX8 and the Pro4 4600.
What a blast! Venom 5000mah 20c pack lasted about 16.5 minutes.
I have a couple questions:
1. Temp got up to about 165 degrees with a 13t pinion while moving, 180 degrees when sitting, is this acceptable. When should I start getting worried?
2. I mounted the RX8 on the ESC tray w/ the servo tape provided in the kit, it didn't hold and the RX8 broke free and was bouncing around. What are you all using to hold down the ESC?
Thanks for all the help!
