SC10 4x4 Thread
I am assuming you mean quiet in comparison to other SCT 4x4s.
It was quieter than my 1/8 electric. I guess I am just not used to the noise as from what someone else said, it sounded fine from what they had seen of another SC104x4.
Anyone know of a vid where someone was bench testing an SC104x4. that probably would help.
For your MMP setup, are you using a BEC or cap, or both?
Thanks for the info. Where did you pickup the Fantom packs?
Anyone have first hand experience with these packs:
http://www.hobbyking.com/hobbycity/s...dProduct=17266
These work fine. They are just as good as my SMC packs. Great punch and runtime is right around 20 minutes. Lets see how long they last. If you order these you should pony up for the UPS 3 day shipping(not really 3 day more like 7). It will cost about 40.00 depending on the weight of what you get but you will receive them much quicker than the cheapest shipping method.
I try to offset the cost by stocking up on the dirt cheap stuff like heat shrink tube, connectors, etc.
All stock settings so far, can't remember what they are, plenty of down low power on our loose track, and was clearly faster down the straight than some of the other trucks here, I have a program box on the way, I think I could add timing as it runs so cool, I do have a turbo fan running over the motor and an old Tamiya heat sink on the motor, it fits great and is pretty big, these were both on there before changing gearing tho, so gearing was the only change.
I didn't see a need. Used smart sense and low start power. Similar to what I do on my 1/8 buggy.
So why did you change to Saddles? Do you like the change what did it bring you? I have a Exotec with std battery in stock location and added weight to rear sides and rear battery side. Trucks still about 1 second off the fast guys at my local track i am still a little green driving, but i was curious to if centering the weight was good? I have a Novak 550 or 540 Can motor and HV pro speed controller which is a monster. So i felt like my motor side weight was heavier than my battery weight. I guess i should weigh the stuff separate to find out real deal on the weight balance
Also boost will make the motor come "alive" as well. Just run a couple degrees and see how you like it.
hey chad,
Thanks for answering my questions I pm'd you the other day about motors. I have decided to go mild for my setup and found a lrp x12 8.5 just like my buddies motor. should take some guesswork out as far as temps lol. also going to rig up a fan and possibly heatsink setup for it.
thanks for helping out a total stranger!!
much appreciated
much appreciated
Probably no video. The day will probably just be a shakedown run for the truck before racing starts. I haven't decided if I'll actually run the truck on the clock, and the track I'll be at is very small, so I won't get much of a feel for what it'll do over large jumps or how well it gets down a long straightaway. Just want to make sure it runs and that it doesn't chew up a gearbox with the Sonic 550 4.5 I'll have in it.
hey chad,
much appreciated
much appreciated
5Likes
