#9991
Well, just ran the SCTE with the castle 1415 / MMP combo on a 2S. With a 20T pinion, it may be good on a small track but needs more top end for Meium/bigger tracks. I have the timing set to normal (8*) now so gonna try turning that up and see if I can fit a 22T pinion. Hopefully those 2 will get me more top, cause otherwise, this motor is really good. It has a lot of grunt, able to clear jumps with little run up, and jumps that I could not clear with a 4.5 or 5.5. Temps were nothing on the motor, but the ESC fan did come on, probably as I was running full pin nearly all the way around the track.
#9992
That was a pretty cool vid, it almost makes me miss bashing my old Slash 4x4. I've gotten so addicted to racing my cars/trucks on the track, that sometimes you forget how much fun just bashing around can be. Afterall, that's pretty much what got most of us into the hobby in the first place
Scott you are right, most of us started out as bashers!
#9993
#9995
Guess that's why I'm a racer and really never drive my cars except short runs to test and tune. Other than that it's always on the racetrack.
One thing I did notice about that vid. To the few guys still complaining that the truck nosedives, I saw none of it in that vid with them jumping quite a variety of jump surfaces.
#9996
#9997
OK...dumb question. These are measured with truck on droop blocks, and wheels/tires off......correct?
Here's the issue I have. I measure the shocks center to center and get them same...then I go back and measure the blue area of shock from adjusting collar to cap and it is a very different measurement. If the shocks are the same length shouldn't this area be the same?
I messed with droop screws but measurement doesn't change when screwing in or out. Bear with me here, want to understand and get this right.
Measure ride hight with full weight, body batteries etc.. basically RTR. This is the distance between the table and your chassis (I say table because you need a flat surface to be accurate). (28mm rear, 27mm front is what I use but obviously what ever you like)
and yes.. the droop measurement is the same with or with out the droop pads installed. The amount the grub will stick out of the a-arm will obviously change, but the actual droop measurement is the same. If you have the droop pads installed do not adjust droop with these.. drop some thread locker on them and seat them firmly into the chassis, only the droop grub in the a-arm should be used to adjust the droop setting.
#9998
I love when UPS and USPS come to my door on the same day!! Got my 2 Losi Xceleron Lipos 2s 40c 5000mah, and my new Iwata HP-CS airbrush for doing some kick butt paint jobs for the SCTE!! Where to start...maybe charge the Lipos's and do some painting in the mean time. Anyone know where to get some extra motor wires? I kinda wanna put some bullets on my Tekin motor so I can change back and forth between the Tekin T8 2650, and the Castle 1410, I tried both the local Hobby shops and all they had was some 16 gauge traxxas stuff too small for me.Also checked a few hardware stores with no luck.
#9999
NIB SCTE located in Central FL, I have the Losi Hardened Diff pins. 300$ looking for local pick-up before i have to ship. 863-582-1077 Alex
I soooo don't get the appeal of bashing and cannot imagine spending this kind of money without the competitive nature of racing spurring me on to buy the latest and greatest.
Most cringe when they see this but I call it durability testing lol. (I was trying to break the chassis)
+ YouTube Video | |
And our track is riddled with douchebags, I would spend more time racing during the week but I can only deal with so many idiots at once.
On a side note we are over 10,000 posts
Hahaha good memory and now that i think about it, i remember u from the traxxas forum too! Too funny. That was a good forum and served its purpose well, but RCTech blows it out of the water. This thread is a great example lol
