I have not run it yet, but I just got the Jammin one because it came with screws. It looks to be high quality just like the others. I am sure the black anodizing is going to be wasted in short order, but I don't really care. It is a race truck. It is not supposed to be pretty all over.
do they make 17mm adapters for the scte 4x4?
After reading some of the posts I have learned some great information. That said I bought the Attebery Performance Engineering titanium hinge pins which he doesn't sell any more. I bought the extended version that can be held with c-clips that way I would not have to put a cover over my carbon fiber hinge pin holder, but after reading some mixed reviews about the snr hinge pin holders I'm a little nervous about buying them and wondering if I should cut my hinge pins down and buy the losi or do you think since they are longer they would work better with the snr over the stock version. Kinda a weird question just hoping some has dealt with this issue.
An alternative for you might be the M2C set, they use larger 4mm pins and have the capability of lengthening the trucks wheelbase by an 1/8" i think. I have seen a few people locally with these installed recently and they look solid.
Either way, you should sell those titanium pins (and get the M2C set) or cut them down and use Losi holders.
scte runtimes?
Hey guys what kind of runtimes do you get with the tekin rx8 and novak ballistic 4.5 running on 5000mah 40c?I feel im getting like 6 or 7 minutes on these packs,is this normal?I picked up a trinity 60c 6200mah pack not to long ago but couldnt run the pack because the front center driveshaft came apart before i could test the new pack,anyone know what the runtimes are on 6200mah driving conservatively on a medium sized track?Any responses are greatly appreciated as i love driving the truck just want longer runtimes if possible.
Never really got an answer. Anyone running a lrp esc in this truck? I know everyone suggest the rx8 but wanted to see if the lrp would work.
Tryed looking through the thread but 1600 pages is alot of reading!
Get a Hotwire, hook up your RX8 and turn down the power to about 80%, that will lower temps and increase runtimes and you shouldnt notice any loss in performance.. I was running 10 minutes on a 5200 turnigy pack with a 5.5 Tekin 550 motor, you should be able to ket close to 10 with your setup on those 5000's. I would get one of the 4 pole motors though, the castle 3800 is cheap, the Tekin Pro4 is obviously better, but costly. A 4 pole will increase runtimes also.
the competition series ones will run 550 size motors just fine.
I personally ran a LRP 5.5 before the Pro 4's were out and ran a Moster heat sink and geared it up a few teeth, Awesome possum.
I personally go Over top of the motor for the fact the Solder tabs are now Riveted in place.
My scte, rx8 and pro4 are on the truck, prob be here in a few days and I'll probably know more bout how it goes together once i read the manual and look at it all. it looks like you solder your wires to the esc, but i am hoping that i can use some bullet style plugs on the other end possibly? I wanna be able to swap motors. If it doesnt come with something like that, i wanna look in to it. i dont want to have to unsolder.
As others have stated, Bullets aren't a wise idea, How long does it really take to Unsolder/Re solder a motor.
Tekin folks recommend soldering the motor this way:
http://www.rctech.net/forum/electric...ml#post9752429
Apparently this decreases the strain on the motor tabs.
Anyone know where to get the front center driveshaft?Its on back order at amain.
Turning down the current limiter does not reduce top end. It might soften the bottom end just a little but most likely all it will do is reduce motor temps and increase runtime slightly with not noticable effect to feel. Reduces the amp spike under hard acceleration.
I'm in the same boat . Been trying to find one for weeks , already rotated my shaft on the coupler and it's already worn like crazy . This Is my only complaint about this truck . That coupler and pin wear extremely fast
