So has anyone had any issues with AE XP 1015 steering servo? Mine seems to FREEZE up sometimes when its fully cranked to the side while driving into bowl turn or sweeper. I have had to really dial down the end points to try to fix this issue and have sacrificed a lot of my steering. Seemed to help but every now and then I get a surprise...
Yes its 100% the servo nothing else. AE even gave me a new 1015 to try to help my issues no luck. I have the feeling this servo doesn't have the Toque that it needs to keep the wheels cranked to the side..
I'm running the 1410 with my MMM. The motor seems very happy with that ESC. For a large 1/8th scale track, go up on teeth on the pinion, try a minimum of 16, but possibly up to an 18. 14 will be too small, it's barely enough for the small indoor track that I currently run on.
looks like strc has come out with some pretty nice parts....
http://shop.ebay.com/i.html?_nkw=los...ab52f749&vil=1
Salad, do you have numbers on the weight difference between the two chassis' (stock scte and erc)? Are you using the factory body? Looks interesting.
It's almost a direct drop in the only thing I recommend doing is getting the Traxxas tie rods from a eRevo to extend the chassis brace. No chance of bending the rear... It's 4-5mm longer than the stock SCTe chassis, the rear drive line from the SCTe is a tad to long, you need the rear drive shaft from a Ten T.
Tie rod installed...
not to step on salads foot here, but when i switched from stock to the erc, i belive it was about 40+ - grams difference. someone please correct me if im wrong, its been a while since i weighed it
Man that grease they use is some nasty crud and fun to get out
It's not 100% the servo because from what I'm reading, AE gave you another and it still did the same thing. That would indicate that the servo is fine but something else is causing it. What ESC are you running? Many with those high volt digital servos have had trouble with ESC's like the Mamba Max Pro. Something else is wrong. That servo should have more than enough torque and speed for our Losi's.
well I guess the steering doesn't actually FREEZE It just gives up. I will fly into a bowl turn with the steering cranked and the steering gives up and the wheels go straight for a second. This happens maybe 5 times in a whole race day. My Steering servo is cranked down pretty tight? maybe loosen it up?
I have found the more steering I have dialed into the truck the more it will randomly give up in turns. So that is why I have backed off the end points and it has seemed to help but not completely.
thanks
Re Ace Servo Woes.
Brass Vs Titanium
There's always a Winner and Loser, Guess who Wins 99.9% of the time....
Brass Vs Titanium
I use RX8's 65C+ lipos.. The guys at WCR said it was the servo. So AE just gave me a new xp 1015 no questions asked.
thanks
thanks
thanks
thanks
I don't... I didn't start taking weight measurements till after the SCTe came out and weight became a question. I use the stock SCTe body with the chassis, fits fine.
