Like Tree9Likes
Old 05-13-2011, 08:13 PM
  #9496
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
Originally Posted by 8ight-e
550 is just longer.. both are about 36mm
Now I'm confused. I have been running Neu motors for a long time and I am very familiar with how they name their motors. I just checked castles site and it says that the 1410 and 1415 are two different diameters. Is that correct? It says the 1410 is 25mm and the 1415 is 36mm. That has to be incorrect for the 1410? Right?
According to the numbers they should both be the same dia. and the second two numbers are definately the length.
alvinsmith75 is offline
Old 05-13-2011, 08:21 PM
  #9497
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by larlev
I would just like to add it's not like the 1415 is so inefficient that you can't run races and worry about battery life. I run 8-10 minute mains and have zero issues with running low on battery.
It is still a really good motor even on 2s geared right of course.
agreed, castle makes very strong motors, just like the 1410 the 1415 is a 4 pole beast.... the 1415 can handle the scte and them some even on 2s geared up and work within temp range. It's just a better choice for those running a 3s setups. I was just pointing out it's not necessarily the best choice for all.. just have to consider if you are locked to 2s if you want the extra inefficiencies.. added heat loss in the coils, and keep in mind the added weight for not only the motor but the extra large pinions.. if you are watching your weight it is something to consider.
Look careful the 1410 isn't shown with a full diameter.. the 1410 is just under 36mm actual diameter.. same as the 1415
8ight-e is offline
Old 05-13-2011, 08:25 PM
  #9498
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
losi guys. looking to possibly convert my ten-te to a SCTE. this is what i have for a parts list. am i missing anything (other than body/wheels)?
Chassis: TEN-SCTE [LOSB2411]
Axle (2): TEN-SCTE [LOSB3574]
Sideguards: TEN-SCTE [LOSB2419]
Front Bumper Pack: TEN-SCTE [LOSB2421]
Rear Bumper Pack: TEN-SCTE [LOSB2417]
Center Rear Drive Shaft: TEN-SCTE [LOSB3578]
Body Posts: TEN-SCTE [LOSB2414]
Wheel Hex (4) w/Pins: TEN-SCTE [LOSB3495]
look good?
RC*PHREAK is offline
Old 05-13-2011, 08:31 PM
  #9499
larlev's Avatar
No, your right. I was just trying to point out that folks considering this motor should rest assured that it performs quite well, and can out pace many other combo's even on 2s.
I do agree however that on 3s the 1415 is hard to beat...really goes good.
larlev is offline
Old 05-13-2011, 08:43 PM
  #9500
10sctrel0v3r's Avatar
ill be picking up a 1410 next weekend for 99.95 guess ill try it out
10sctrel0v3r is offline
Old 05-13-2011, 08:53 PM
  #9501
ScottKelly911's Avatar
Originally Posted by stompy
And do you know the part #
The part numbers are on the first post of the first page of this thread along with pix. It's a super useful post and SaladFork keeps updating it to include the latest parts and useful tips for this truck, so keep checking back
Originally Posted by SCTRacerX
Also does any one here use a power screw driver to work on RC's? I have been looking at a few and most are around 100.00 for a small driver, anyone had any luck with a cheaper driver for wrenching on RC'S? Don't want to strip things out but would like to speed the process up, I seen the guys at the hobby shop using power tools and the light bulb went off in my head like ooh yeah why didn't I think of that. Still haven't found a great tool for the job yet.
I use the Ryobi 4v, $30 bux at Home Depot and it has an adjustable clutch so you dont over tighten stuff. This thing has made my RC life significantly better! Then I used the Losi 8-1 tool for the tips, they fit the driver perfectly
http://www.homedepot.com/webapp/wcs/...cStoreNum=1002
http://www.amainhobbies.com/product_...Hex-Wrench-Kit
ScottKelly911 is offline
Old 05-13-2011, 09:10 PM
  #9502
look good?
Looks good to me, need two pair of the axles and dont forget wheel nuts. Ours just came out, I would get the serrated nuts.
hacker07 is offline
Old 05-13-2011, 09:53 PM
  #9503
RC*PHREAK's Avatar
Awesome. Thanks! Do you have a part number for the nuts?
Old 05-13-2011, 10:07 PM
  #9504
I don't know if Losi came out with some serrated wheel nuts, but most people use the Traxxas blue Slash 4x4 wheel nuts because they're serrated, cheap and look good. I think Pep Boys even carries them since they carry Traxxas stuff, or at least they used to.
http://www.amainhobbies.com/product_...ed-Nuts-Blue-4
Old 05-13-2011, 10:09 PM
  #9505
Ridley's Avatar
Should sway bar have side to side/up and down movement, or just up and down? What are the set screws for?
I know you guys have said "move freely"..just want to clarify.
To me it can't work if side to side play is there. Am I wrong?
You can't have too much play really. As long as the bar is in the retainers, you can take the little set screws out and it won't make any difference. If they are too tight, you will feel a difference, so erring on the side of sloppy is good.
Ridley is offline
Old 05-13-2011, 11:13 PM
  #9506
Suspended
hey all me again the nut putting the vxl in scte. well with 3 batterys threw and 10 min. hard passes then checking temps. cool down for 5 min. in between, never got above 111 running and 122 at a stop, so far so good. i started in the basement with a 12t. my 14 and 16 t are coming in soon so i can up my temps a little. but even with just the 12 she is tourqey out of the hole and still good up stairs. dont worry my 3800 1410 and mmp are on their way. just ordered, had this laying around so why not throw it in while i wait. did better than i thought. well i will update with pics and vids later on. well thanks for all the help
rcman45 is offline
Old 05-14-2011, 05:09 AM
  #9507
http://www.homedepot.com/catalog/pro...ce5716_300.jpg
I use the same little drill works great but you don't have a chuck which is fine I made up a adapter to put a old small drill chuck on so I could drill holes with it at the track without buying the drill with the hex end.
Mike1977 is offline
Old 05-14-2011, 07:57 AM
  #9508
Integra's Avatar
I have found that you do have to change your oil out a bit more often. Please keep in mind, I mostly run on indoor clay tracks. I would consider keeping them on if I ran outdoor (after soaking them in oil for a few days).
Soaking them obviously makes them a little softer and less prone to tearing ill assume ?
Hitachi All the way, The Makita is imo a little larger then I would personally prefer. A Clutch is Very Important at first to learn the gun and how powerful it is. If your on a serious budget the cheaper units from Home depot or your cheap tool center's will work, But the hitachi is Imo the best of the best. Light weight, powerful, 2 batteries, And A LOT of people use them at the track so If you forget to charge a pack or something more then likely you'll have a spare on the next table.
Originally Posted by Chase1472
I see a lot of sponsored guys use them. Makita has couple but all the good ones are $100+...
Hitachi is under 100$ and the best of the best.
Originally Posted by SEF
Ryan said the carbon towers are in stock. Not sure about hinge pin retainers.
You can get both from Steve at SNR http://www.snrgraphite.com/index.php...index&cPath=13
He doesn't have his carbon hinge pin retainers on his site, but email him at [email protected] and he will get them to you.
the weight difference is more drastic then normal as the stock plates are steel not alum like on 95% of other kits. While the SNR plates are a Big weight saving's I feel for most of the SC racing population the Steel was a Very Smart idea on Losi's part to keep those arms/toe plates in check.
Integra is offline
Old 05-14-2011, 07:58 AM
  #9509
the 1415 is a 550 sized 4 pole motor, the 1410 is a 540 sized 4 pole motor.
The 1410 on 2s will have as much or more torque as the 1415 on a 2s setup due to the low RPM's on the 1415. You can gear up the 1415 to get similar maybe even more effective torque but at a huge cost of efficiency.. both in heat and how much mAH you burn off your batteries.. it is very inefficient running at that low of a RPM. The 3800 is just under 30k which is the "magic" number, the 1415 is only at like 18k rpm which is pretty bad. On 3s lipo it's another story altogether.. the 1415 is pretty sweet.
thanks Eight! I don't know all the technicalities but you said what I wanted to say. Thanks
LRPO is offline
Old 05-14-2011, 07:59 AM
  #9510
Originally Posted by jurquhart
I believe I had a 19 tooth pinion gear
I'm geared at 20 on 2s and 3s
LRPO is offline
