#1996
those hopup pivots don't look like they have any more options vs the stock choices. Stockers look more than durable enough. I doubt those carbon shock towers offer much more than a few oz savings. If they drop front spindles, I'll go for those the rest looks unnecessary iMO. Thanks for the thoughts though. I'll wait till parts wear or break before bothering.
The carbon towers or the fancy aluminum ones aren't very expensive and HAVE to be tougher than the stockers
Aluminum spindles is probably the least needed option parts the truck needs...the stock plastic is amazingly durable.
#1997
[QUOTE=hgrove99;8744759]
Seeing as we all just got the proper gearing from losi on wednesday, nobody has had much of a chance to test much yet. I'll be headed to the track tonight and will post up temps and battery usage on the 1415 with the 20/40 gearing on 2s.
I've been loving the CC 1410... For how small it is, it's been faster than any of the 4.5 cans I tried (The SP V10 is very close). We also ran the 1415 on 3S today at the track, started 11t and could have used a 13T for more strait speed.
I also have the Tekin 5.5 and have ran both 2 and 3S, it's works awesome on 3S, 2S also works fine but I had more fun on 3S .
Check out the size and weight on a few different motors. I would recommend the 1410 all day.
ME
Im putting an mmp sct w/1415 and i have roar legal 2s 5800 battery packs...can you estimate what kind of run times ill be lookin at?
WOW IM SORRY I REALLY MESSED THIS QUOTE UP SOMEHOW
ME
#1998
In case anyone is wondering about the stock tires. They look like they would work pretty well. They look just like PL Bowtie 1/8 scale tires (Not the bowtie SC tires) They feel like the compound is in between M2 and M3. If you can't find wheels yet (most places have them now) and you're wondering about racing on the stockers, I would say that unless you are running on pure indoor smooth clay, the stock tires might be a decent choice. I won't get to try it on the track for a few more days, but those are my initial thoughts.
#1999
Sorry for back to back posts, but here goes.
You Losi team guys: I have an xcelorin 1/10 scale esc that has worked just fine for me (unlike the 1/8 scale esc) anyway, I was thinking about trying this out with my Novak Ballistic 4.5 550 motor. I've never messed with the timing or anything on this esc, but can you guys list your settings on this ESC?
I have the Losi software (probably need to do a version upgrade) and the plug to attach to the computer, I just need recommended software and firmware versions and what the settings are.
Thanks!
Thanks!
#2000
You really shouldn't make statements like that as if they are fact. In fact, I ran a Novak ballistic 550 with a MMP all last season and had not one single issue. I do know that lots of them did, but for whatever reason I did not.
I think it was due to me NOT downloading a buggy firmware update and because I use an analog servo, but for whatever reason, mine is absolutely wonderful. Smoothest esc I have ever used.
Actually, the rear shock tower is pretty prone to bending. My buddy bent his wednesday with the factory bumper. The one on mine has been bent a lot and hammered back straight each time, lol. It's just a thin stamped piece. You'll notice the body won't want to fit right before anything else, but it's pretty much guaranteed it's gonna get tweaked
I personally like having tuning options and rather have the parts ready to be replaced than be at the track and not have them
#2001
#2002
i got this truck monday, buy surprise i wasnt expecting it till sometine later this month, my thoughts are this truck handles, turns and jumps with ease straight out of the box, a few set up changes and tires, WOW!!!!! its un beleavable, allmost has the same charactoristics as an 1/8 scale. power plant im using is a mmp sct pro 2400 w 15pinion on TP 45c 5000 3s rought about 20 min run times temping 100 on avg. buy far the best sct 4x4 that i have driven. the only bad thing is the rear shock towers bend forward if lands on the roof. other than that awesome trucks. good by slash 4x4
#2003
Forgot to ask saw plenty of people noting hop ups.. but do you really need any hop ups at all? I saw on casey's he had the alum pivot supports and hubs, or is it just a little bling basically? I know I don't need any upgrades on my 8ight-e, it's a frickin tank... hoping for similar luck w/ this sct.
Thanks!
Thanks!
#2004
Thanks!
Thanks!
You can get the software and firmware downloads here.
http://losi.com/Support/XcelorinDownloads.aspx
You need a 32bit windows XP machine though. Anything newer and the driver for the usb adapter will not work!
Settings.
Lipo cutoff- (I run nimh mode to not use it but if you run for long periods of time set this to 3V/cell)
Brake/Reverse- Forward w/o reverse
Throttle limite- 0%
Motor Timing High (4*)
Brake %- I set at 80% and then turn it down on my radio
Initial acceleration- High
%Drag brake- 0
I use a Spektrum radio so I set it it 2.4ghz
I run stock dead band which I think is 4.
Hope this helps.
#2005
You're welcome
That is my best setup so far, running a Neu 1409/1Y w MMP (extra caps on esc), I have all Novak's 550's and both of the new CC motors for SCT's and still find my Neu 1409/1Y to be the best
+1 I own 3 MMP's with no issues and only recently decided to put extra caps on 2 of them for a peace of mind rather than I needed too
+1 on the towers and don't forget about the rear hubs that have been said to break as well. I ordered the f/r carbon towers aluminum hubs and f/r pivot hinges and sway bar set right off the bat.
Then the other issue is the rear shock tower is kinda flimsy.
I also have not had the diff pin wear some were having...and all my diffs came from ten-t's. I use mugen diff fluid, but that shouldn't have done anything to prolong longevity IMO.
Nothing real serious, and I have around 15 weekends and 10 or 11 A Main wins on the conversion truck.
IMO, this truck is a STEAL for what you get, the performance, and it's durability. There isn't anything else out there even close at the moment.
#2007
I see I got a lot of catching up to do
It won't take long
#2009
Out for delivery ups needs to get here!!
#2010
I'm hoping so, but one thing I learned on here fast, is that for some reason we use more battery and run higher temps than what many post on here IDK exactly why, maybe because we drive harder, have tackier tracks, use more brakes, spend less time upside down, or simply don't exagerate...whatever the reason....we are always at the upper echelon of heat and battery consumption. For instance, I was putting that much or a little more back into my batteries when I was running this motor at a dog turd slow .44 ratio.....so I know it will be more now at .50.
Case in point #2, was my buddy about melting down his novak 4.5 yesterday with the recommended 16t pinion gear Came off somewhere over 190* with only 10* timing
Here is a typical track we run, my losi is the bright yellow one starting 4th on the grid. Whats the Losi doing 4th on the grid...well, I can thank my trusty MMP for that debacle...RX8 in for the main, though I still blew my chance with 1 minute left. That race was with a novak 4.5, geared 17/52, came off at 165*, and used around 6200mah in 10 minutes.
http://www.youtube.com/watch?v=xsGF1...layer_embedded
That track is really huge. I'm thinking the reason you're seeing higher temps than normal is all those badass long sections of track. That track is easily double the size of what I ran mine on.
