On some servos the linkage hits not the nut or screw. 22 servo horn works awesome and same length as regular al horn on inside hole.
What's the best chassis? Just kidding, but I actually just bent my stock chassis and was thinking about going with the kh chassis. Does everything from the stock truck bolt up to that chassis? Radio box, braces, etc?
Yes Sir, everything from the stock truck will certainly bolt up to the KH chassis with no issues. The only question is the rear brace which i am sure the stock one will work, but they may may an additional hole for another rear brace for a tuning option of course.
does anyone know what the difference between tekin pro 4600 and tekin scx4 4.5 i am running the 4.5 in dirt oval and its pretty fast.
The longer brace is usually used on high bite tracks?
Thank you! I just ordered one. I have another question; is the tlr high performance body any thicker than the stock body? I like the looks of it but the stock body is so thin and fragile and I'm wondering if the high performance one is any thicker?
High performance I don't believe is any thicker and is pretty fragile IMO . Jack celts much thicker, I just bought 3 high performance and had them custom painted and painter said he will see me again in 6 mos lol, but I really like the looks. My next ill proly go back to Jconcepts
The TLR bodies i have painted are definately thicker than the stock body so yes they should last much longer. Plus they do look cool and perform better on track!
Also, this is a good body and got good durability reviews here...
http://www.liverc.com/news/special_f...rtcourse_body/
I had about 12 runs on my SCTE with the stock body which has big cracks on it but still pretty usable lol. Omg the stock body is thin though !
My kingsheadz chassis started to crack but they are going to replace it.
As per instructions, yer supposed to remove that bolt under the motor.
Been running mine all summer an into the indoor season with NO issues whatsoever. Truck has over 55 races and counting. Not to mention practice days.
Just picked up an scte used and need some new wheels. Looking at either DE Racing or Avid's, what do you guys run with good luck?
