Like Tree9Likes
Old 10-22-2012, 06:00 AM
  #40381
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by nanoverse
I have never needed two gaskets. When I first tried to get the gaskets tight and put too much rtv sealant on the gasket and putting rtv first on the inserts I got lockup. Just put the insert in first (hard), then glue or rtv. After that put brake/motor cleaner on gasket and soak/smear in rtv. After that diffs have been butter.
I did 2 gaskets only on the front diff. It was my first diff to put ca on and i seem to have gotten tiny bit too much, just enough for it to lockup. I got it right on the other two diffs and used the ca more sparingly. No need for a second gasket.
Rockthecatbox21 is offline
Old 10-22-2012, 06:57 AM
  #40382
rcguy76559's Avatar
Trader Rating: 22 (100%+)
Originally Posted by timannnn6
Understand that 8200mah at 30C is 246 amps continuous!! Plenty for our trucks. When running more mah you do not need "75C". Probably false claims anyways.
C rating is a bs # there is no standard on it. Theres bunch guys running turnigy 6000 packs the black ones think there 25-30c there like 25 bucks each. With no issues. I been running 6600 nano tech packs with no puffing for a year now. Just keep those temps down and run current limiter. Also check all bearings in truck. When temps start getting hot.
rcguy76559 is offline
Old 10-22-2012, 08:35 AM
  #40383
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
Good weekend at the Sc Showdown. Ended up 4th. In 4wd Sc there was all the way down to a L main. 270 Entries i believe.
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-showdown.jpg
"Smiley" is offline
Old 10-22-2012, 08:40 AM
  #40384
Adonis_mp's Avatar
Trader Rating: 9 (91%+)
I keep going back and forth with my Pro4 4600kv on 2S and my CC 550 on 3S. I like the sensored feel and responsiveness of the Pro4 but I keep getting pass on the two long straights on the 1/8 scale track. So I guess what I'm looking for is a 4pole sensored 550 motor, any ideas?
Adonis_mp is offline
Old 10-22-2012, 08:49 AM
  #40385
Casper's Avatar
Trader Rating: 34 (100%+)
Tekin has mentioned a 550 4 pole called the Pro-4HD. It should be here soon as the annoucement was a while ago but not sure on the time frame.
http://www.rctech.net/forum/10671790-post2691.html
Casper is offline
Old 10-22-2012, 08:52 AM
  #40386
nitro_mt_racer's Avatar
Trader Rating: 241 (100%+)
Your track let's you run 3s in 4wd sct? What esc are you running?
nitro_mt_racer is offline
Old 10-22-2012, 08:54 AM
  #40387
Resqnu's Avatar
Trader Rating: 37 (100%+)
Default Rear Brace
Ordering the Bump chassis. Which rear brace do you recommend? Delrin, TLR torque rod or other?
Resqnu is offline
Old 10-22-2012, 08:55 AM
  #40388
caguilar4's Avatar
Great job! Any video footage of the race?
caguilar4 is offline
Old 10-22-2012, 09:02 AM
  #40389
Grandturk's Avatar
I have stock, TLR rod and the long Delrin brace available as tuning options. I've been using the TLR rod lately. It's a good in between feel. Use the Bump Delrin brace on high bite tracks where you can't seem to get the back end to rotate enough. I found the truck to be very quick to rotate with the Delrin brace. Use the stock brace for low traction conditions and the TLR brace for in between.
Grandturk is offline
Old 10-22-2012, 09:05 AM
  #40390
Grandturk's Avatar
What are you getting passed by? Rocket ships? I keep up with ebuggies and truggies with my Novak 4.5 550 on the straights.
Old 10-22-2012, 09:07 AM
  #40391
Resqnu's Avatar
Thinking of buying a strc front brace and center diff support. Are they needed?
Resqnu is offline
Old 10-22-2012, 09:15 AM
  #40392
Grandturk's Avatar
Not by me. I use the stock plastic front brace and stock center mounts and motor mount. I would not use aluminum braces.
Old 10-22-2012, 10:08 AM
  #40393
"Smiley"'s Avatar
Here is some video I found of the 4wd Main at the Showdown..
http://www.youtube.com/watch?v=nfdla8dwAes
"Smiley" is offline
Old 10-22-2012, 11:09 AM
  #40394
symmetricon's Avatar
Trader Rating: 27 (100%+)
Great job Smiley! Its nice to see an H-town guy bring it!
symmetricon is offline
Old 10-22-2012, 11:38 AM
  #40395
Adonis_mp's Avatar
We are not too stricked on the rules, we don't have big turn outs so they try to fit group as close as possible. We some times have to mix 2wd SC with buggies or 1/8 nitro with 1/8 electric. I'm currently running CC MMP.
