I noticed some of you guys used the inside hole on the Losi Alum servo horn ? Im guessing its ethier for less throw or more important less of a angle.
Feint: Hum yea im guilty of that one lol.
It's easier to take out steering throw if you don't need it.
But if you tune it down to what the inside hole would provide naturally, then the reality is that you're just stressing the servo out more and making it more prone to failure. The longer the lever, the more torque/power it takes to provide the same amount of force. Also, the longer the lever, the more pressure the wheels and objects you hit give back to your servo saver, servo/gears.
It it a huge deal? No. But all the small things add up.
But don't come here and stick your nose up at electric folks, because you're running the same truck and using lipos as well. Thanks.
General info RE: chassis. I've now tried the BCE (limited), Bumps (8+ months) and Kings Heads (2 months) and stock. So far I'm a fan of the Bumps then KH in terms of handling. I like the KH in terms of the updated drivetrain geometry and I think this will make a great outdoor chassis come summertime when mah might be a factor (we have some larger outdoor tracks around here). The BCE seems very stiff and doesn't handle as well as the Bumps. The un-treated aluminum seems to get a grimy funk to it after a while. Not sure what that is, but it doesn't affect performance.
I suspect the TLR and Bumps chassis are very, very close.
since i have 3 outdoor tracks and an indoor with in 30 mins ill keep out of this argument oh and it was 80 here in south florida!!!
That's what I was wanting to know, was drivers input on their chassis and setups.
Thanks geohm
Thanks geohm
Ya, some of us dont live in CA where its nice a majority of the time...and we have 1 track within an hour or 2 and i work til 5pm six days a week and when i do get out its almost dark and lately its been raining and our local track is open 2 days a week with 1 being a race night and i dont have a transponder so i can race on fridays and im not always free the 1other night so for some of this, this is all we have and is our rc release
Yea I forget about climates around this time of year is bad for most.
Only way to find out, is buy what you like and drive it. All tracks are different. I've had most of the aftermarket chassis, they all work really well. So whatever you get is most certainly better than stock.
Inside holes give you more torque and less of a twitchy truck, which is the primary reason to run it there. You can run it to the outside and (de)tune from there via your transmitter if you want.
Oh i see yea il try the inside hole than once i get a new servo for the SCTE.
Feint: I have a local indoor carpet offroad track thank god ! No racing in the winter sucks big time .
Just something to look at if you use the inner hole on the losi aluminum horn- make sure it doesn't hit you servo when close to maximum throw- you can either notch a small spot on your servo for clearance, run the stock horn which raises the angle of the linkage or use a losi 22 horn which is angled up to clear your servo
If I recall, Aaron Lane's setup was popular for trucks that haven't gone on a diet (weigh close to stock). Ryan Dunford's (hacker) is very similar, but geared towards lighter trucks. You can then tweak for track and driving style. I use about 80% of Hacker's (I have a rear mount battery) and really only adjust tires between tracks - so you can probably find one and just stick with it.
