Im running a tenshock sc411/hobbywing esc combo and using turnigy nanotech 6600mah batteries and noticed my run times are not what they should be.. instead of 10-12 minute times like most people at my track are getting I get about 8 minutes. Nothing is binding and I run smoother than all of the people Im comparing run times too so I know its not my driving style. I had a very basic Dynamite charger and just yesterday bought a new imax b6 ac 80w charger so Im hoping that solves the problem. Is there any way this can be a motor/esc issue? I have my low voltage cut off set at 3.4 but most packs were at 3.8 when checked after running.
What kv motor do u run? My 5200 will use 6000+ mah in an 8 minute race.
It could be your nano has lost its ummmmph!!
I find their punch dont last long, lucky to get a race series out of them before they become practice packs , i have 7 of them, i just bought a revtech 6900 to see hows its lifespan goes
Does any one know if they will up date the truck to a TLR soon.
you plug the hole after set up?
I just bit the bullet and picked up the bleeder caps. Was really tedious to do it with the stock caps.
why is that? the video looks simple
i have aluminum caps
ok i aluminum shock caps that have a small breather hole in them. if i switch to emulsion and follow the video wont the air and oil bleed out of the hole in the cap?
nobody's thrown a pin through the king headz retainer sleeve?
