Like Tree9Likes
Old 11-11-2012, 03:13 PM
  #40981
Allen720's Avatar
Trader Rating: 33 (100%+)
Originally Posted by chucko
When you screw the cap on..... the hole..... is below the seal at the top of the shock body
right but by running emulsion there will be no bladder and there will only be a oring of sorts. do you want the shocks to be able to breath?
Allen720 is offline
Old 11-11-2012, 03:42 PM
  #40982
dtr
dtr's Avatar
Think about that o-ring for a minute; what do you think it does?
dtr is offline
Old 11-11-2012, 03:51 PM
  #40983
Allen720's Avatar
i havent opened my shocks yet so i am not sure where the hole corresponds to the out side. does the o ring sit over the vent on the inside
Allen720 is offline
Old 11-11-2012, 04:23 PM
  #40984
tony montana's Avatar
Trader Rating: 76 (100%+)
im having a hard time to get my shocks to feel smooth. The springs always run the shock bodies and to be honest my shocks feel like crap lol. My truck is all stock so any suggestions?
tony montana is offline
Old 11-11-2012, 04:30 PM
  #40985
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Make sure the springs are fully seated on the shock collar adjusters.
Rockthecatbox21 is offline
Old 11-11-2012, 04:42 PM
  #40986
dtr
dtr's Avatar
The o-ring are at the same place where the rim of the bladders are (originally most racers just cut out the middle of the bladder), so they are at the top of the shock, compressed between the cap and the shock body to seal the shock.
dtr is offline
Old 11-11-2012, 04:57 PM
  #40987
Allen720's Avatar
thank you i have taken them apart now and see. The vent is like inside the threads of the cap and once the o ring is on there is seals for that vent. got it. i appreciate the info. sorry for all the questions.
Allen720 is offline
Old 11-11-2012, 05:30 PM
  #40988
chucko's Avatar
Stock shocks springs rub. springs sets are better. springs fit better to clear threads. also bladder absorbs shock on compression,.. cutting the bladders gets you shocks that feel better and are more forgiving,... smoother makes your car handle the jumps and gets better traction.
chucko is offline
Old 11-11-2012, 05:57 PM
  #40989
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
Finally got it up and running today - I have been short on time....
Its got the TLR kit, RPM a arms and bumpers, the Losi buggy body as an over tray to keep the electronics clean, and stock body painted (un-professionally)
Kept all of the wires black and put black shrink tube on the other wires, like servo and speed control leads.
Hitec servo, RX8, 4000kv 4pole and yep a Eco lipo battery, from Amain.
That 5000mah pack is only 30c, and lasted nearly 25 min, just having fun driving in the yard.
OG RC 10T is offline
Old 11-11-2012, 06:07 PM
  #40990
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
I love my Losi with the MIP kit. It's the easiest thing to drive now.
JEFFs SC10 is offline
Old 11-11-2012, 06:16 PM
  #40991
Ralph289's Avatar
Do you have a part # for the Losi buggy body you used and how do you keep it on ?? Velcro ??
THANKS
Ralph289 is offline
Old 11-11-2012, 06:42 PM
  #40992
Allen720's Avatar
how much shock fluid should i use with the bladders cut? like 50% up and fill fluid to the top?
Allen720 is offline
Old 11-11-2012, 06:43 PM
  #40993
timannnn6's Avatar
Trader Rating: 140 (100%+)
Originally Posted by Casper
You don't need to use grease. A lot of guys just up some shock only on them to lube them before a build.
Please tell me this is auto-correct talking. If not Casper...you're slipping.
timannnn6 is offline
Old 11-11-2012, 07:34 PM
  #40994
TCCustoms's Avatar
THANKS
Looks like he might have used velcro or hasnt done the holes yet buy you can use the 8ight buggy body mounts(rear mount is longer than the 810 mounts) as i did and the 8ight body as its longer. Ive heard people use the 810 body but i couldnt get it to fit(to short) so i went all 8ight gear...Works great but havent did temps with it yet when its warm/hot out
but all you need is the 8ight body mount kit(comes with fuel tank stuff too)
and any 8ight body preferably one uncut so you can move it to where you want it and open holes up for ventilation
TCCustoms is offline
Old 11-11-2012, 07:41 PM
  #40995
OG RC 10T's Avatar
It's a standard losi buggy body, and I used velcro
