This thread is getting too infused with drama, and on it's way out. Thus the problem with threads that grow to 2 million and a half pages.
Speaking of the SCTE, how about that Ryan Dungey! Haha
2 little problems i found when building.
#1 the body posts do not quite fit the towers. I had to dremel them to allow the nut to sit flush. Even that its not perfect. You will have to redo your holes in your body to accommodate.
#2 the steering linkage on the inside requires you to use 2 of the smallest tapered washers i have ever seen. Its dam near IMPOSSIBLE to get them in place without it dropping or flying off the linkage. Took me almost 30mins to do that alone.
I found the body mount thing to be alittle upsetting myself... You can only use the outside holes on the rear... unless you shim the mount away from the shock tower to clear the nut on the shock standoff... I'll be honest I didnt even try to put those dubro ends on with the shims... but at least I know what to look forward too...
Other than that this kit is quality... cant wait to race it...
So Ive seen someone with some Losi Eight shocks on there Losi TEN.
What would I have to get to use these? New shock towers?
Oh Ya ,question for Lord Casper.....On the Tekin Pro-4 motor I have ,it is very near new bought it used cuz it was a little much for the Guy,one of the solder tabs is loose that connects to the little vertical board.Will this affect anything??He says it was like that since new and alot of them are like that???
I have asked around and there is quite a few that seem to be like that!Any thought would be appreciated.Thanx!!
I do have the 8ight shocks and I think u have it backwards since u want a taller tower due to the taller shocks and don't need the stand offs as the bolts work fine just get the 8ight bushings for the shock caps! If u use the 8ight stand offs u will have to drill out the tower holes for the larger 8ight stand offs and I won't use the 8ight stand offs on my new SNR towers becuz if I do it will make for less support where the holes are and to do that doesn't make sense when u can use the scte stand offs or bolts just as easy without ruining the integrity of the tower just to use stand offs from for the 8ight....but that's me! So if someone wants 8ight stand offs I will sell them and they are brand new
But get fronts and rears...and the bottoms might need a few small washers but don't remember right off hand and also the bushings for inside the shock cap hole
XOXO
legit.
still makes me laugh, but my favorite was the bumper sticker one.
