Like Tree9Likes
Old 07-07-2012, 11:05 PM
  #36616
scracer68's Avatar
Originally Posted by HighLife420
You not kidding...wow...
No, put it together wet and let it dry before putting it back in, i stood it up.
Here is pics of my MIP build, cant wait to try it tomorrow.
Can't wait to hear how it does. Do you think the shield will raise your temps?
scracer68 is offline
Old 07-07-2012, 11:34 PM
  #36617
HighLife420's Avatar
Trader Rating: 49 (100%+)
If i had to guess, then yes, i think it will raise the temp of my ESC by a few degrees.
Will report back tomorrow after the races.
HighLife420 is offline
Old 07-07-2012, 11:36 PM
  #36618
Trader Rating: 6 (88%+)
http://www.amainhobbies.com/product_...ck-Set-4-8B-8T
Would these work on my Ten SCTE?
Ironwolf1974 is offline
Old 07-08-2012, 06:37 AM
  #36619
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Ironwolf1974
Yes they will fit, all you really need is a couple of small spacers on the shock stand off's behind the top bushing (3mm).
That said they are really a waste of money imo, I had a set, tried a set and run stock shocks. I even had the 8ight shocks on my 810 and recently swapped back and I'm using stock shocks with the m2c pistons and 27.5 oils and the buggy feels 100x better. To get this out of the way I race on a pretty huge 1/8 scale track with motoxross style jumps... 8ight shocks add weight and do not reduce run times or improve jumping vs the stock shocks setup correctly. Now if you do have some control issues and are looking to increase durability.. I can honestly say it maybe a fair mod. That set doesn't come with springs.. I'd get some silvers all around, maybe even want reds. Start with 40wt front 30wt rear.
PS the 8ight shocks are longer than the stock shocks and you WILL need to use the droop grubs on the a-arm and if you don't have an upgraded chassis I would also order a set of 8ight droop pads and use them on the stock chassis to avoid the grubs just digging into the chassis and making it very hard to set droop height.
8ight-e is offline
Old 07-08-2012, 06:57 AM
  #36620
TCCustoms's Avatar
Yup or pick up the new take off's on eBay for cheapers, they come with springs and use money saved to buy a few sets of springs
TCCustoms is offline
Old 07-08-2012, 07:18 AM
  #36621
chucko's Avatar
8E 2.0 Losi spring rates
Front
Red 2.3X4.1 For losi SCTE using 8 shocks Red front 35 W #54
Green 2.3X4.7 rear silver 27.5W #54
Black 2.3X5.0
Silver
Rear
Red 3.1X2.5 Losi 8e Front Black 27.5W Rear Green 22.5W using valves
Green
Black 3.1X3.4
Silver 3.1X2.8
if you want to use the 8 shocks heres the break down. have fun
run the red front and black rear either 53 or 54 size in front depending on track size
chucko is offline
Old 07-08-2012, 07:47 AM
  #36622
8ight-e's Avatar
Front
Black 2.3X5.0
Silver
Rear
Green
Black 3.1X3.4
Silver 3.1X2.8
The 8ight reds are as light of a spring as they have, the slivers are next in line, then green then black being the stiffest.
I wouldn't recommend black rears... even on the much much heavier 8ight-e nobody runs that stiff of a spring. Typical 8ight setups are silver or green, but most are green on the rear. Some have moved again with the much heavier 8ight to a black front spring, but still most stick with a silver to green front spring as well. Just some thoughts..
8ight-e is offline
Old 07-08-2012, 07:55 AM
  #36623
larlev's Avatar
I agree....blacks do not work on our trucks. Run red/red, red/silver, or silver/green(indoor only)
larlev is offline
Old 07-08-2012, 08:29 AM
  #36624
TCCustoms's Avatar
Front
Black 2.3X5.0
Silver
Rear
Green
Black 3.1X3.4
Silver 3.1X2.8
hey guys...i added this into the "Losi 8ight shocks on Losi SCTE" thread also so it will be easier to find and also wanted to post here so if more kno anything on set-ups/what they do/how they do it with the 8ight shocks they can go here also for info! Thanks guys...
Old 07-08-2012, 08:42 AM
  #36625
chucko's Avatar
one of the reasons I suggested silver in the back is because. I tested off a jump and it helps with kicking the ass end right to keep the nose from diving. sounds backwards. but with the stiffer spring the back end helps the line, it didn't kick as much as a soft spring. try some different springs to suite your driving skills and track
chucko is offline
Old 07-08-2012, 10:02 AM
  #36626
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by BashemSmashem
I assume you mean BowFighters as P/L doesnt make a Crimefighter for SC ?
If so I think the are great tires for hard packed dirt with a loamy/dusty top , wet or dry .
I would compare them too the Losi Eclipse tires but a little better side bite .
Regular buggy Crimefighters are awesome as well when the track starts getting chewed up .
I've been using RTV for the last 2 builds. Works fantastically. I use a little on each side of the gasket and let dry. It hasn't leaked a drop since.
Pics coming of the MIP build. Just watching the UFC fight at a buddies house.
no, i meant the crime fighters as that is what came on my mugen truggy yesterday. Good to know they're decent tires and from what i hear they should work great for my local track.
I actually used some permatex high-tack gasket sealant on the inserts and it works fantastic. Have had absutely no leakage so far. Just be sure to wear gloves when applying this stuff as it is very sticky and hard to get off your fingers unless you have some paint thinner lying around.
Rockthecatbox21 is offline
Old 07-08-2012, 10:36 AM
  #36627
Hi guys about a year into rc and I want to start racing and like the SCTE. So my question is what motor and esc are you all using? I will being racing it in a 4wd Sct class of course and have no limit on motor or esc. In price I want to be under 250 in the motor and esc. I know I am leaning towards the MMP for the esc. Please any sugession are appereciated. Thanks
BADxDREAMS is offline
Old 07-08-2012, 10:44 AM
  #36628
scracer68's Avatar
Hobbywing Xerun SC pro esc
Hobbywing Xerun 4000kv 4 pole sc motor
As good if not better than anything out there.
Old 07-08-2012, 10:46 AM
  #36629
scracer68's Avatar
Thats less than $200 for both I think, check here.
http://www.falconsekido.com/
Old 07-08-2012, 11:00 AM
  #36630
oh and was wanting to to be sensored my bad
