Ya don't blame You ,if I was any closer I would live at that track!!!Some fast trucks there for sure as well(fast to me)I ran there on triple A main Sunday and slotted B main TQ and had some of the best 3 car clean battles ever.All three mains with the same two guys and both ran me clean and hard just perfect door to door racing ..in a Bmain no less!!Great facility and crew as well!!
Have fun !!! Hope to get Lapped by you guys some other time
As of today I have a new web site:
www.APE-RC.com
I have a pointer on the old site to the new one just in case.
www.APE-RC.com
OK, just ordered the SNR carbon +9mm towers to accommodate my 8ight shocks since like i said before i dont have stock shocks so i am selling(once again) the brand new STRC towers in silver that i have on ebay right now as a pair and ive had a few PMs about the brackets i have on top of the stock towers and will be selling them soon so if interested let me kno by PM
But i will report back on the SNR towers when i get them but for $20 more than what i paid for the STRC towers and still having to have the bracket on top of the STRC to make for longer length i just wasnt happy with doin this and would have to drill through the towers for the 2 holes on the rear i believe and did not want to do that to brand new towers so i never opened them hence why im selling them
i kno but with the taller towers or the goofy setup i now have it handles pretty good even with the 1/8 rims/tires since i havent swapped due to not having any scte rims since my slash rims/tires wont fit or be in the same position now with the body being jacked up so tires dont rub til i get the SC tires on. And i have 4 sets of 1/8 rim/tire combos so im ready for dirt or pavement and but once i get all this little stuff done i'll get some SC tires mounted up.
But if you make it the towers taller you wont need the droop pads as there arent any stock droop pads and didnt need them on the 810 so if i give it a taller tower it will be like having overgrown stock shocks and wont have to worry about the droop pads, drilling out the arms, replacing the droop pads, if the hex wears out/strips just another thing to work on when i can avoid by doing taller towers...it all makes for a good excuse for me not to do it, ok, there...thats the better answer for me
www.APE-RC.com
www.APE-RC.com
A friend of mine has just received his SCTE today and after looking the truck over, we noticed the truck had a 2.0mm swaybar in the back and a 1.8mm swaybar in the back. Is this standard? I thought the truck was supposed to be setup exactly like the setup sheet that came with the manual running 2.0mm front and 1.8mm rear swaybar? Everything else seems on par!
Are any of yall running the m2c pistons and if so what weight oils? I put them in using the same 35 front 30 rear that I was using with the stock piston and the rear end is bad loose. I know I need to go heavier just not sure how heavy. The only other change I made was moving the camber links out on the hubs. I know this could effect it some but I've gone from one end of the spectrum to the other. I'm thinking about going back to the stock pistons but hate to give up on the m2c ones so quickly. Any feedback would be greatly appreciated.
Thanks,
Thanks,
I just got a SCTE Ten used and I see a cap with a brown and red wire leading out of it.
Does this go into the battery plug on the reciever?
