tell me about it, arrggg
Is there any places with the king headz chassis in stock?
Does anyone have a good base setup for med bite technical indoor clay. I have scte bce tlr kit 4600 pro 4 rx8. Thanks
Does anyone here run the pro4 4600 with a MMP? If so can you pm me your settings? Thanks
Ok well then i guess mine is bad or something..at full thottle the pro4 completely shuts off the reciever...im already running a cc bec on it! Any help is appriciated.
If you are running the bullet connectors on the motor, make sure they fit supper tight. If not pry the 4 parts of the bullet open with an x-acto blade to obtain a tighter fit. Mine shut off at full throttle until I noticed the loose fitting plugs.
Im not running bullet connectors though!?!
hey guys
i just brought 4 of the nano tech 5800 2s 30 to 60c lipos
would these work with my scte with a hw & tenshock 4600 combo
Hey guys with stock springs what shock oil is a good starting point? Also does anyone know what the stock oils are?
Ditto...or more or less if i run 2s lipos, what would be a good set-up to run without breaking the bank?? Im not gonna spend $200 on a esc even tho i kno alot of people say you get what you pay for but i think there are cheaper options and i dont really race so dont need the cats meow
