R/C Tech Elite Member
Thats what I had before I got my SCTE and it was night and day difference, the Losi was way easier to drive and drive fast!
Well im looking forward to it, I gota get used to rc again and get it dialed in by august for the short cource shootout in omaha
I agree with Goehm on these batteries. I haven't seen a need for 3s. I've been running in 95+ temps with very minimal puffing at all on my GensAce 5000mah 40c batteries. I run 3 of these batteries and rotate them between my XXX-SCB, XXX-SCT, and my SCTE. My SCB and SCT are both running Tekin RS with a 17.5 and 10.5 Tekin Redline and my SCTE is running the RX8 with a Pro4 4600 and I haven't seen any issues.
Hi guys,
I'm now 4 days from getting my SCTE ten and I was just thinking : this SC has the same chassis than the losi 1/8th buggy right?
Any idea which part you have to change to convert it to a buggy if I fancy that later?
I guess for sure wheels and body, plus getting rid of SC body pins and bumpers, what else?
Hi guys,
But, I'm not sure exactly what you need. I suspect just wheels/hexes, and a body, along with some body mounts.
To ease your effort, just know that it shares design/parts with the 810 buggy, not the 8ight buggy. The 8ight looks like everything is similar, but everything on that buggy is sized bigger then the SCTE/810 counterpart.
I may not search for an exact clone of 810 or 8ight.
I just like to change the aspect of my cars sometimes, and if only wheels body and mounts make it a 1/8th buggy, I think I'll like that from time to time.
For info I did like to "transform" my Kyosho lazer into a rallye-car with a Porsche 997 235mm wide body...
Sorry to bug...
John
My quess is throttle control and tire choice.On your radio go negative with throttle expo down as much as -40 or 50!Try that
Well documented in this thread ,truck requires a very good battery with a high -C- rating.The gearing and esc settings would be a band aid fix for( lack of battery) Cheers!
Hi guys,
Important differences.. Chassis is shorter, rear center shaft is shorter, body mounts, wing mount and wing, axles and 17mm nuts
If you honestly think the Stock Chassis is up to the task, Your Seriously mistaken. It will tweak if you look at it funny. So Imo some form of Aftermarket chassis IS needed.
I have found the stock chassis to be very durable. I have flat landed, cart wheeled, and lawn darted with it many times and it is still straight as an arrow. Maybe the newest version is a bit tougher than the earlier versions?
Hi Casper, I'm currently going through all your suggestions and I bumped into just one little thing that's driving me crazy: "THE DROOOOP"! I don't know if I've misunderstood the setup sheets, but am I supposed to unscrew the set screws so they don't touch the chassis? Or am I supposed to screw them all the way in and back out two turns?
Sorry to bug...
John
Sorry to bug...
John
Do the JC hazard wheels fit on this truck? Do they hit the body? What do they do to performance? I have some from my SC10 that I would like to use before I can rebuy sets of tires on SCTE wheels.
but my shocks, especially the rear ones, become quite longer than what's written in the setup sheets. Is that ok?
