Since i cant find another thread thats active about the hobbywing xerun v2 i guess ill ask you guys. I have the v2 as ive stated and it seems to heat up really fast whenever i use a 4 pole motor. As an example i ran it up and down my driveway for a minute or so and it was already at 114. So does it just run warmer with 4 poles or do i need a new software. I have the 3.2 link and have no boost timing and 6 degrees turbo. I usually use the copperhead esc but i am trying to use something a little lighter.
On another note, the turbo isnt helping anything. The only way I got it to work in my Dingo was running it in blinky mode.
Im just gonna take it out. The miniscule weight savings are not worth the potential for dnfs.
I think i am just gonna keep the hobbywing as a backup even though i hardly doubt i will need it
Fella's - here is one for you:
I have an SCTE I bought second hand that is pretty stock - Carbon towers is the only 'upgrade' (necessity) after I found they were bent. However, out today doing some practice laps I found that my chassis is bent like a banana. Not kidding, gotta be out by 5-6mm in the middle.
The issue is that I LIKE the way it drives! I'm winning the A-main at my local track consistently, it's a great car, but the chassis is bent and I dislike that it's bent and I don't want to spend $40 on another and bend it too. So, which chassis (I know, we all ask this question), BUT, which chassis doesn't bend in 5 race meets and performs the most like the stock chassis?
Thanks!
Thanks!
Thanks!
Thanks!
First three truck have the exact same setup spiring's oil diffs and tires
Fourth truck running stock shock oil and no front sway and 1.8 rear sway with bump chassis
First truck stock chassis I ran pretty consistently around 16.2 running 4600kv pro4 and rx8
2nd truck kingheadz chassis I ran 16.0 and fast lap being a 15.9 bh esc Orion 4.5t 550
3rd truck mine just changed chassis from kh to jammin ran 16.0 pretty consistent fast lap was a 15.4 bh esc Orion 4.5t 550 I used around 400more Mah with this chassis than the kh chassis motor was 150 after 8min .
I felt the jammin chassis fit my driving style better and rotated better for me.
4th truck bump chassis the setup on this truck was a little different than the first three I was running 17.5 with this truck fast lap being 17 flat mmp 4000kv pro4. It probably was just the setup the truck seemed to have to much rear bite and I couldn't really get it to turn in even with the battery all the way forward.
This is just my experience in not bashing any chassis.
R/C Tech Elite Member
Trader Rating: 123 (100%+)
Thanks!
Thanks!
NEW to the MIP chassis, I was at the track the other day running some laps and doing some tuning when I decided to REALLY tune my truck.. I tried another losi at the track with the MIP chassis installed and I bought the chassis right then and installed it at the track. After flawless installation I ran my truck and it was outstanding the way the truck performs. Kept my setup the same with the tlr shock towers and shocks. (no bi-pass) I'm running on indoor CARPET, so if anyone has some carpet set up suggestions for the MIP please share. My truck is pretty dialed and seems very planted. Running 1/8th sway bar in the front (2.5mm). Here is a few pics, decided to shorten the servo wire and try to clean it up a bit. First time trying anything like that, normally it looks like a spaghetti mess! lol!
Pic
Trying to find the updated diff gears on line. Does anyone known if there are two part numbers for the newest version of the updated gears.
k thanks
