Hobbywing ESc
a great esc for this truck from HOBBYWING is the SCT Pro, its a sensored esc, with great power and control... i run it with a tenshock 5200kv sweet set up!
What was wrong with the first run rollers diffs? Just the diff pins themselves?
Registered User
ebay link for esc
Whats everyone think? Here in MI the ground stays damp til mid afternoon(usually when we run and the track is usually damp and the grass most def is) so i'd like to get something water resistant/proof but didnt kno if this was decent
oh my gosh! you guys reply fast! Anyway..........
Seems like the center diff has a lot of back and forth play don't know if i need to add shims or if it's a bearing clearance issue.
The SCT-Pro without program card ends up being about $6 cheaper.
That's Hobby Hot's ad that you linked to on Ebay as well so you're still dealing with the same vendor, except not paying a middle man.
Let us know how it goes and what battery you're using (2S?). The 150A is a pretty serious ESC. I have been running it's little brother, the 80A, in my 1/8 scale (just switched to the SCT-Pro). Very good ESC.
I was looking on ebay and saw there was a waterproof esc made by HW but it was 120 amp...
ebay link for esc
ebay link for esc
Comes with timing built in, so you'll want to tune that out. Other than that it's really plug and play.
Thanks. Got NIB one for real cheap. Keeping all the drive hits and plastics and diffs with replacement pins. I know they updated the gears and front drive shaft as well but they will work for my purposes.
It's a HOBBYKING 120A sensored/sensorless esc 1/8 1/5.From HOBBYKING not hobbywing. You can get them at Hobbyking.com. They have them in stock right now and when they are out it takes awhile to get them in stock again. They cost $41.73. I would post a link but I can't.
