I run the Hitech HS-7955TG and run it at 2S LiPo voltage 7.4v and so its faster and stronger than their specs. Sure it isn't rated for 2S on paper, but there are threads on here where Hitec employees chimed in saying it absolutely can handle it fine, they just dont put it on paper as they have models that they want you to buy for more $ to run 7.4V to them.
Any suggestions on digital servos? Switching from Spektrum to Futaba radio and want to take advantage of the faster radio speed. Currently using a Hitec HS-965MG with a RX8 and Pro4 4600. I was looking at the Savox SC-1258TG and the Spektrum S6040. I've had glitching issues with Savox servos in 1/10 scale buggies using MMP and Tekin RS with Spektrum receivers. Is anyone using Futaba/RX8/Savox without any issues? I don't want to run a cap. Any other suggestions? Thanks.
i have used both the savox 1258 and XP DS1015. the savox was nice when it was in there. it stripped a gear and in went the 1015. no problems at all with the 1015 so i'd recommend that over the 1258. savox did replace the servo even though they say they don't cover stripped gears. i run it with an RX8/airtronics receiver and no cap needed. i didn't need a cap when i ran the savox with a hobbywing SC8 and airtronics receiver.
I had to untread my front shock rods and im wondering do i just turn the shock rod intill its with the shock line intill the shock rod end is tight ? I tryed it and i measured it from the bottom of the shock cap to the smooth end of the plastic shock rod end with diginal Calipers and one was quite a bit off not sure why
Also one of the shock rubber boots teared im not sure why Losi still will not make thicker shock boots there to thin .
Grats to Casper and "Hacker7" on taking 1st and 2nd at JBRL round 2, you guys have helped me in so many ways getting my truck to handle my poor driving!
Link to their JBRL pic!
http://www.jimmybabcock.com/images/2..._Rd1/Pro-4.jpg
doh, broke my bumper
^1 LOL mine broke too the first time out. Snapped right in front of where those screws pulled out...I guess it is pretty common on these trucks.
Mine lasted around 30 packs so wasnt so bad, time for a bit of bodging i think, im not spending out on a full set of bumper plastics for just one part
Thankx FLHX1550 maybe I'll get the 4500kv and use a 14t pinion as our track has alot of tight turns and only one straightaway that your wideopen .Will the 4500kv give me enough bottom end to get me over a good sized triple with a short runup distance and witch of the two will give me lower running temps or are they pretty equal? Thankx again Bob
There are allot of things that go into jumping a technical jump or rhythm section on a track, not just power. Traction (not enough grip to make enough speed), setup (chassis dragging the ground on the up-face), driving line (momentum), and driving style all play a part in it. You would be surprised how little power it actually takes to get a car to fly a long way, and how you can get more air by just changing how you approach the jump.
It's just hard to say if one motor or the other is better / worse for a particular jump on a track I've never seen.
Scott
