My Truck was so on Rails last night in our Club Race!! Truck is just Sick right now!!!!!!
http://www.amainhobbies.com/product_...nectors-4-Male
other connectors have melted my batteries, and some batteries with low C ratings and bad solder joints will just melt on their own.
3s will be much more efficient and run at lower temps. You will not need so much mah to get runtime. I ran 3s with a Castle 2600 kv motor for a long time and got 10 minutes on a large fast track with 4000 mah 45C 3s batteries.
On the same track with the Pro4 4600, I dump right around 8 minutes with my 6000 mah nano-techs.
send that pic...along with the pics of the other 3 which im sure are all cracked to jconcepts. they gave me an $18 credit to use on their site. they are well aware of the problem and are at least doing that to help.
Which bullet connectors are you using? Some have more resistance and generate more heat than others. I've had good luck with the low profile 4mm connectors like these
would I get more top end with 2400Kv on 2s than 3s?
would these do?
Hey does anyone know what kind of setup phend is using? Chassis, motor, speedo, etc....im thinking about getting one of these beasts!
Wow really! i am going to have to research pics of that. I am surprised that thing doesnt over heat!
Need some advice as I'm tired of second guessing.
There is a big smooth sweaper that the truck is on rails(so I think), then there is another that bumpy while making a left right before a 180 right. As going through that rough sweaper the front end is too bouncy and kind of hard to control.
Front set up is 32.5 oil with #4 piston emulsion style
Middle upper shock mount and out on the bottom side
Stock sway bay
Almost no droop
Edit.. I've had my de wheel for about a year mainly used in big tracks with no issues
Stock sway bay
Almost no droop
You guys that are melting your packs , are you guys using the charging harness that comes with the pack to run your trucks ? If so then THAT is the reason your packs melted .
Do not use spring banana plugs for running your trucks as they do not fit tight enough and have a lot of resistance and will heat up like you guys described and from Feint Motions pic .
agreed on the losi wheels, they have been by far the toughest and the stiffest wheels I have used so far out of proline, Jconcepts and losi. I just got a set of black DE wheels for super cheap from a friend that sold his scte and Im not too happy about hearing the above. One thing i did notice about the DE is they are very squishy like the PL renegades, it wasnt an issue with the PL ones for me i hope it wont be an issue with these either. I was gunna start racing again indoors and was thinking either PL suburb 2.0 or aka rebars. Anyone have any feedback on the suburb 2.0's, does the wider contact patch help? Ill be running on a smooth clay track that if they leave it long enough blue groves up very nicley but they never really let it groove up nice cause they change it up pretty frequently.
Are the new TiNi coated shock shafts and hinge pins available yet?
I am running the DE Racing wheels with the 17mm hex and love them. I never understood why the 4wd sc trucks use 12mm hexes with powerful brushless power systems. Yeah 17mm is a bit of overkill but no DNF's from broken or cracked rims. The best part is that we as Losi owners have the benefit of running the 810 17mm axles with no modification or 17mm adapters.
What would that be?
