When will the
LOSB2187 Losi Pivot Ball Set, Hard Anodized
be available again??
I need some really bad!!!
I'm getting ready to order new shock pistons and was wondering if anyone has tried the m2c pistons? If so would you recomend them over the Losi piston set?
I haven't tried them in an SCTE but I have used them in a 8T and they worked. I can tell you DON'T USE THE RC SHOX 2 stage pistons..HUGE WAIST OF MONEY, they don't work as advertised..
I don't know what's going on with the stock of parts for the SCTE. I know it popular, but I also know that racing season isn't even in full swing and a ton of stuff is back ordered. I've been waiting for the lockable hex's for over a month from my LHS and the rear spring set for over 3 weeks now. I know I can online and get it but jeez.
Google is your friend.
http://www.hobbyfever.com/product_in...ducts_id=14773
Somebody else got another place where I can buy this item??
I just ordered the CNC 7075 Lightweight Bump Chassis for Losi TEN-SCTE and the TLR Tuning Kit Combo from nitrohouse.com for $189.95. I've read nothing but good things on the Bump chassis so I couldn't pass up on the deal. Here's the link if anyone is interested. http://www.nitrohouse.com/Car-Hop-Up...duct_info.html
Regional Moderator
Hate to do this but I'm going to part with this...
http://www.rctech.net/forum/r-c-item...l#post10210057
I am looking more more motor choices I run at an indoor clay track it is kinda short and tight I am running a 4.5t sonic right now with a 12t pinon and I can't seem to use all the motor except on the stright but every where else on that track I get cough easy by the sc10's that everyone seems to own there what would be a good choice for motor and pinon size?
I run a Mamba Monster as a SC
I currently use them. They definitely make a big difference both compression and rebound wise. Start with 30wt oil and you should be within 2.5 of where you will need to be.
Does anyone know if it's possible to get replacement drag link screws without buying the drag links & hardware package (LOSB2279)?
Was hoping there were some generic screws I could buy since they seem to come packaged from Losi.
Thanks.
Thanks.
R/C Tech Elite Member
