Like Tree1Likes
B44.1 Thread
Old 07-19-2011 | 10:45 AM
  #436
Is it possible to run stick battery in the 44.1? I've got 5 for my b4.1 would really like to save some $$..
GuiltyByAssoc is offline
Old 07-19-2011 | 11:29 AM
  #437
Originally Posted by Banshee8530
48 pitch... the included spur gear in the AE kit is 48 pitch.
Thanx Banshee
And the 48 pitch pinions are all the same diameter, so that they will fit the Tekin shaft?
Can't really tell the various brands apart, which material would suit the B44 better? Does it have a "favourite" brand/material?
19quiz76 is offline
Old 07-19-2011 | 11:31 AM
  #438
AFAIK - no
I found out the hard way - *after* I won the eBay auction on my B44
19quiz76 is offline
Old 07-19-2011 | 12:05 PM
  #439
No, must be saddles. Yes, the selection is limited and expensive...
Originally Posted by 19quiz76
Thanx Banshee
They should fit. Due to the fact this is an off-road car, steel is the best bet.
EricJ is offline
Old 07-19-2011 | 01:06 PM
  #440
Thanks, Eric - I'll go for 48 pitch steel
Soo, um.. I guess I'll end up with a Tekin RS RSC, Redline 7.5T motor and a 22T 48 pitch steel pinion
Thanx for all help, guys!
19quiz76 is offline
Old 07-19-2011 | 01:10 PM
  #441
^^ Thanks guys! Saw a roller for $80 at ocrc, almost pulled the trigger.
Old 07-19-2011 | 01:26 PM
  #442
Buckaroo's Avatar
Gens Ace saddle pack, click hereCheck out the Gens Ace saddle pack. Great pack, awesome price.
Buckaroo is offline
Old 07-19-2011 | 01:27 PM
  #443
What's to think about?!? I don't even want to say what I paid for mine, now..
19quiz76 is offline
Old 07-19-2011 | 08:06 PM
  #444
A lot less than I paid for mine, too.
19quiz76: If you don't have them, you should probably get a full set of pinion gears, up to about 30, then select your spur gear and ratio based on motor temperatures and the track... Of course, I'm not familiar with Mod setups, so maybe gearing isn't as critical as it is in Stock...
EricJ is offline
Old 07-19-2011 | 11:24 PM
  #445
big chris's Avatar
Anyone have a link to a good setup for a rough outdoor 1/8 style track? The 4 on the rc10.com site just are not what our track is like. I have driven it with the all tracks setup and it needs a little help.
big chris is offline
Old 07-20-2011 | 12:17 AM
  #446
Good idea - do you have a link to a good set, preferably steel?
19quiz76 is offline
Old 07-20-2011 | 01:40 AM
  #447
old-man's Avatar
Check this out too -
http://www.hobbyking.com/hobbyking/s...dProduct=17274
old-man is offline
Old 07-20-2011 | 03:31 AM
  #448
Lonestar's Avatar
Hi all
just about to pull the trigger on a b44.1 order... what are the must-have spares for this baby? Any must-have options (I'd think not, as it's AE!)?
Thanks for the help
Paul
Lonestar is offline
Old 07-20-2011 | 03:36 AM
  #449
big chris's Avatar
Originally Posted by Lonestar
Hi all
Thanks for the help
Paul
Front shock shafts and shock rod ends. That's a quick lesson I learned the other night. Of course front arms. I also bought the ballast weight for in between the batteries.
Old 07-20-2011 | 06:23 AM
  #450
Would these be the right ones?
Shafts:
http://www.amainhobbies.com/product_...hock-Shaft-102
Ends:
http://www.amainhobbies.com/product_...m-Eyelets-Blue
19quiz76 is offline
