B44.1 Thread
#586
).I was thinking of mounting the transponder on the front top plate near the antenna mast, using servo tape.
#589
The notch on the turnbuckles that comes with the b44.1....goes on entire leftside of car which I did...but a friend told me it goes on the leftside meaning lookin at car from the front....which to me puts it on the right side of car lookin at the car from the back. Help???
#590
Also, here is what my wiring looks like with the front top plate removed. Simple, clean, nothing too fancy.
#591
Unless I have a defective 44 or 44.1 chassis, it does both.
I took a 44 chassis and bolted it to the underside of my 44.1 chassis at three points. I then took a felt pen and marked-thru the 44 chassis, onto the 44.1, to see where the mounting hole lined up. The 44 mark was both behind/rear and towards the edge/outside of the 44.1 mount.
Note: The mounting hole by which the mark appears is towards the centerline of the chassis.
#592
TJmac...is that the new r10? Did u change the wiring on it to all black? If so were did u get the wiring and wat size....i have a r10 coming....thanks man.....p.s. Any concern of the wiring being close to the driveshaft ...slipper spring etc? Oh can u take a pic of the rear hubs...outdrives actually....thanks
#593
#594
Yup, mine are under the top deck. There is more room than you think and unless something pokes through your body and down onto those three wires, they will never come in contact with the slipper spring/collar.
#595
I'll get you a pic tomorrow....anything in particular you want to see with the rear outdrives?
#596
got my lrp 6.5t and tekin rs pro in this week. soldered it up and wow.. im loving how easy it is to change set ups with the pro. can you guys recommend which saddle pack to run with. i know the gens ace are cheap and people are having good luck with them but its only a 25c rating.. should i look at reedy or smc... i think i could beat my slash 1/4 throttle on the track!
#597
#599
Someone on the forums also recommended Pro Match but their only saddle pack (5200mah 50C) is listed as out of stock.
http://www.promatchracing.com/prodde...?prod=2S5200SP
1Likes
