Like Tree1Likes
B44.1 Thread
Old 09-07-2011 | 06:55 PM
  #616
Anyone using a Castle MMP does it fit?
jmoneym is offline
Old 09-07-2011 | 08:57 PM
  #617
It fits but it is TIGHT. I am not a fan of it in there but it'll fit. Going to try an SP in it next.
kstoracing1 is offline
Old 09-07-2011 | 10:00 PM
  #618
Hey guys I put kyo regular shocks on and big bores on and the big bores barely fit. You have to put them on the outer holes to clear the body in rear. Both shocks are great performance wise, well older ae anyways. Buildability goes to kyo and takes the win for me. I like that I can get all the same all the time and in a hurry too.
Ostach24 is offline
Old 09-08-2011 | 01:17 PM
  #619
TJMac's Avatar
Originally Posted by VandelayInc
I purchased Reedys. 5200 60c....great batterys. I wood look at reedy or orion
Hey Vandy what are you using to charge/balance them? I noticed that Reedy doesn't include a charge adapter. Did you already have a saddle pack adapter or did you buy the one Reedy makes?
TJMac is offline
Old 09-08-2011 | 01:22 PM
  #620
They come with a lead. Slap a deans plug on and you are ready to go.
goin2drt is offline
Old 09-08-2011 | 04:56 PM
  #621
TJMac's Avatar
I thought they came with a jumper and two bare bullet plugs (that's what AMain shows in the pictures)?
TJMac is offline
Old 09-08-2011 | 04:59 PM
  #622
Mine came with the plug you need to charge. Positive, negative, jumper and 4mm bullets. All I had to do was solder on a deans and away you go.
goin2drt is offline
Old 09-09-2011 | 05:43 AM
  #623
Lonestar's Avatar
Hi Guys I'm done with the build of my b44.1... this is my first 4wd offroad car since I ran my original xx4... last millenium
A couple of things that have me puzzled, was wondering if you could help.
1- wobbly front wheels. The rims look fine, it's in the hex I'd say. Any known way to assemble them or mount them on the axle that'd minimize this? It's visually pretty scary to say the least. Any special tips on the hexes to prevent losing them everytime you change the fronts? Thanks
2- the steering post holes in the top deck are ridiculously much larger than the the plastic part that's supposed to go in it. This creates absurd amounts of slop in the steering system. Did I get a lemon, or is this common? Is it worth trying to fix?
3- the car still sounds like a pepper mill despite breaking the primary drivetrain in for like 6hrs with an old brushed mill under 3V and shimming this properly (I think, at least definitely not on the tight side)... this is appalling, really.... any fix?
4- Center cvd cups - all wobbly on the slipper axle... is this "normal", again?
Thanks all for the help
Paul
Lonestar is offline
Old 09-09-2011 | 05:53 AM
  #624
Default See below
1- wobbly front wheels. The rims look fine, it's in the hex I'd say. Any known way to assemble them or mount them on the axle that'd minimize this? It's visually pretty scary to say the least. Any special tips on the hexes to prevent losing them everytime you change the fronts? Thanks Gonna happen. Even the factory guys do not have a tight front end. They like it that way. Hex should not come off with the pin in.
2- the steering post holes in the top deck are ridiculously much larger than the the plastic part that's supposed to go in it. This creates absurd amounts of slop in the steering system. Did I get a lemon, or is this common? Is it worth trying to fix? Issues here. Get a new top deck from AE. Mine is snug.
3- the car still sounds like a pepper mill despite breaking the primary drivetrain in for like 6hrs with an old brushed mill under 3V and shimming this properly (I think, at least definitely not on the tight side)... this is appalling, really.... any fix? Mine is smooth. I would check the shims again, gear mesh.
4- Center cvd cups - all wobbly on the slipper axle... is this "normal", again? Again you have issues. Mine are tight as can be. Maybe you used the wrong pin to hold them on.
Paul
Answers above
goin2drt is offline
Old 09-09-2011 | 06:10 AM
  #625
Lonestar's Avatar
Answers above
Interesting - thanks.
re #1 - were you referring to losing the hexes, or the wobble? it's mostly the latter I find surprising, really
re #3 - what drives me nuts is that I'm supposed to know about conical gears pretty well... my 8th scaler is usually looked at best-in-class in terms of freewheeling at my track, it will spin forever. Current shimming is 3+3 on both sides, and the backlash is "just right", less shimming to free it up will mean too much slop.
Will check #4 - then again I have no pins left once the build is done now
Thanks - feel free to comment anyone???
Lonestar is offline
Old 09-09-2011 | 06:34 AM
  #626
I meant the wobble. I was concerned as well. Happened to have a few AE drivers at the track I go to a few weeks back and all their cars did the same. I think the shims are 2/4. I would check the manual. Lastly my pins that hold on my hexes have to be installed with pliers. No chance of them coming out and a hex falling off.
goin2drt is offline
Old 09-09-2011 | 07:19 AM
  #627
mjk1210's Avatar
is the peppermill sound coming from the pinion or gear boxes? I have mine shimmed WAY beyond the manual and after 9 months the gears are still like new and my b44 is the quietest car of the 4 I drive.
mjk1210 is offline
Old 09-09-2011 | 07:51 AM
  #628
Lonestar's Avatar
Useful and reassuring - thanks
Paul
Lonestar is offline
Old 09-09-2011 | 07:55 AM
  #629
Lonestar's Avatar
Gearboxes (both), clearly. I could feel it even when they weren't assembled to the chassis yet. Instructions is 4+2, 3+3 is even looser actually so it should be smoother, but then again all parts kind of cool differently depending on manuf'ing batches, so they should all be shimmed differently. If I shim it even looser than it currently is, it's going to become too fragile (too much backlash). I could not see any burrs on the moldings... I'm really puzzled by that one. My TC3 (which used the same componentry) was much better than this, even without blueprinting it. I mean, HP is not a problem these days with crazy BL and lipos capacity, but still, it's unnerving... screws aren't tightened too hard, diffs turn "true", I've shimmed it to the best *I* could and by golly it's noisy and tight, even noisier than my 8th scaler that has full metal gears...
oh well. I guess I'll run it like that
Paul
Lonestar is offline
Old 09-09-2011 | 09:22 AM
  #630
TJMac's Avatar
I just thought of something...are you sure you have your hexes on the axles correctly? You mention loosing them, if your car is built correctly there would be no way for this to happen as the hex slides onto the axle and is then captured by the axle pin. If you put the pin on first then the hex I could see them falling off when ever you changed your front wheels.
TJMac is offline
