Like Tree1Likes
B44.1 Thread
Old 10-15-2011 | 09:02 AM
  #766
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
Originally Posted by Jeauxkor
Im new to the B44. I just built two of them and spent lots of time painting my bodies and undertray only to find out they dont fit my chassis. I have the regular B44 not the .1. I assume the chassis is different length? The undertray is for a 44 but the bodies are for 44.1. Suggestions?
I would post the bodies up in the for sale section. Then purchase bodies to fit your B44. Or, if there are any local racers who run the B44.1 see if they are interested in the bodies.
SpraydbySprague is offline
Old 10-15-2011 | 10:01 AM
  #767
I have seen a few put the body on a 44 and cut the front way back, but it kinda looks weird because the undertray comes out from under the body.
Ostach24 is offline
Old 10-15-2011 | 10:51 AM
  #768
Jeauxkor's Avatar
ok so here is my next question, what else is affected by the different chassis? Are all the other parts compatible as far as drive train and stuff like that?
Jeauxkor is offline
Old 10-15-2011 | 12:42 PM
  #769
Everythng is compatible.
goin2drt is offline
Old 10-15-2011 | 12:47 PM
  #770
Jeauxkor's Avatar
Thank you.
Jeauxkor is offline
Old 10-16-2011 | 12:32 PM
  #771
Originally Posted by Teufel Racing
I'd like to know about the drilled pistons as well,
I did some checking and the #1's were already #54 sized. I was thinking of another hole as well. Hopefully we'll get the scoop
OK. I spoke with Maifield last night. He told me the set up sheet does not tell you that he used a #2 or #3 piston in the rear shocks and drilled out the existing holes with a #54 drill bit. The #54 is slightly smaller than the #1.
zipperfoot is offline
Old 10-16-2011 | 02:13 PM
  #772
racer1812's Avatar
Super Moderator
44.1 body on the original 44 chassis will require that you dremel material off the chassis on the front. You will need to scrap the 44 undertray. The length isn't the problem, it's the angle of the chassis in the front.
racer1812 is offline
Old 10-16-2011 | 11:14 PM
  #773
jirish617's Avatar
i dont own a 44.1 but thought id let you all know if your looking for another one
amainhobbies.com has them for waaaaaaaaaay cheaper than tower and most other places, i think its posted for $229 brand new versus $369 over at tower.
jirish617 is offline
Old 10-16-2011 | 11:34 PM
  #774
The $229 is for the B44 not the B44.1, still a great deal though. Thinking about picking one up!
Used Up Junk is offline
Old 10-16-2011 | 11:38 PM
  #775
jirish617's Avatar
ooops! didn't even notice, well it is still $20 cheaper than tower! lol
Old 10-16-2011 | 11:43 PM
  #776
No biggie, a guy I race with told me about the deal at A Main that's why I knew it was the B44 not the .1 Hard to beat that price though for a car that is still at the top of its game.
Old 10-17-2011 | 12:09 AM
  #777
Guest
What size screws are needed for the B4 wing mount modification? For the battery post and especially for mounting the wing mount itself? It would probably be a good idea to use as long screws as possible.
rctechuser5108581 is offline
Old 10-17-2011 | 01:06 AM
  #778
RCmayor's Avatar
If you use the B44 modified mounts, 5/8" screws are good and you need a 21mm spacer to bridge the gap between the mounts. Not sure on the B4 mounts. I think the modded B44 mounts work a little better since the wing mounts at least sit on the rear tower mount. The B4 mount mod just hangs off the back of the car with no vertical support. Plus you don't have to buy B4 wing mounts to do it mod, they probably aren't that much though... I posted some pics a couple pages back.
You don't have to use a battery post. Any aluminum tube with 4/40 threads or 3mm threads will do. I use a cut down 1/8 radio tray post for mine.
RCmayor is offline
Old 10-17-2011 | 02:20 AM
  #779
Guest
It seems that at least Neil Cragg had a similar modification at the worlds:
http://jconcepts.smugmug.com/RC-Raci.../O/DSC4561.jpg
http://jconcepts.smugmug.com/RC-Raci...O/img11423.jpg
http://jconcepts.smugmug.com/RC-Raci...O/img11458.jpg
http://jconcepts.smugmug.com/RC-Raci.../O/DSC4606.jpg
Old 10-17-2011 | 05:34 AM
  #780
A main had the 44 for $219 a few weeks ago. I had to pick one up for indoor. It came with some updated parts. V2 slipper and .1 top deck with the front antena mount. I don't mind the old shocks so it wad a no brainer for me. By the time I put some updates on it I still won't have the price of the .1. So I'm happy..lol
DHMOTORSPORTS is offline
