Hyper TT 4wd 1/10th Truggy Thread
#2086
STRC cv shafts for Hyper 10sc
STRC has just released a heat treated carbon steel cv shaft for the Hyper 10sc and Hyper TT. These cv bones work with existing Hyper 10SC/TT Axles and joints and should be much more durable than the original cv shafts.
Part# STO21016
Available at Nitrohouse.com
Part# STO21016
#2087
STRC has just released a heat treated carbon steel cv shaft for the Hyper 10sc and Hyper TT. These universal bones work with existing Hyper 10SC/TT Axles and joints and should be much more durable than the original cv shafts.
Part# STO21016
Attachment 706199
Part# STO21016
Attachment 706199
#2089
#2090
That's a great idea
#2091
Is there any better dogbone for this truck?
#2092
Part# STO21016
Attachment 706199
Part# STO21016
Attachment 706199
#2095
What he said.
Bones and upgraded tougher stub axles, I'd buy two sets right now.
#2096
TT
Yosh 70
I always give 140 as a max due to a slight fluxation in temp guns and I would feel bad if I said 170 and someone burned up a motor using that number. I've also found that power starts to drop off after 145-150 on motors...and it can't be good for longevity.
Hyper..
I don't think we'll be back till March..just too much going on right now. Then again you never know. When will the next track change be? Not being regulars it's nice to travel in on a fresh track. Come race with US at RACEWORLD this Sunday. I've been talking to TAZZ and trying to get him there. We have 3 titty twisters. Great track and warm everywhere.
A quick update on my set up. I have the rear shock in the upper outer hole and middle on the arm. I had to use the upper holes on the tower to get the dog bones level. Front shocks are middle tower and inside on arm. ream camber links are bottom hole on inside and outside on rear hub.
Mike
Hyper..
Mike
#2099
As for the questions regarding the dog bones and axles there are currently no upgrades for these parts.
The STRC cv shaft is a replacement for the stock cv shaft only and still uses the stock cv axle and cv joint hardware (pin and barrel)
#2100
I love the TT I would buy one if they didn't break every time I watch them
race at the tracks I race at.
They all have switched to SC10 front bumpers because stock ones break in
the first 5 minutes of racing. The rear axle stubs snap like pop corn. The
plastic seems to break if you look at them sideways. The guys that win are
the guys that get lucky and don't break.
What is the list of things you need to change to not have these truggies
break all the time???
