Team Associated RC8Be Thread >
Old 07-27-2010, 12:46 PM
  #46
kaisertrip's Avatar
Default Titanium
Hardness. Titanium is a much harder metal than aluminum and approaches the high hardness possessed by some of the heat-treated alloy steels. Iodide purity titanium has a hardness of 90 VHN (Vickers), unalloyed commercial titanium has a hardness of about 160 VHN and when alloyed and heat-treated, titanium can attain hardnesses in the range of 250 to 500 VHN. A typical commercial alloy of 130,000 psi yield strength might be expected to have a hardness of about 320 VHN or 34 Rockwell C.
Impact Resistance. Knowledge of tensile strength and ductility of a metal is insufficient for many engineering applications without the knowledge of toughness. Titanium falls among the few metals capable of possessing good toughness along with high strength and ductility.
Titanium may have impact strengths ranging from more than 100 foot pounds Charpy for the higher purity iodide product and 30 foot pounds for the commercial unalloyed product to 1 or 2 foot pounds for some of the high strength but brittle alloys.
http://www.keytometals.com/Article126.htm
kaisertrip is offline
Old 07-27-2010, 01:16 PM
  #47
Leodis's Avatar
Trader Rating: 16 (100%+)
Originally Posted by GAMBITX View Post
here are a few pics with the lunsford titanium screws and AE aluminum hopups
FYI, An engineer with Horizon Hobby told me I should never screw titanium screws into aluminum threads. Something about a chemical reaction if I remember correctly. Screwing them into plastic threads and steel threads is OK.
P.S. Lunsford screws are so pretty. Too bad I've already sunk so much money into my RC8Be.
Leodis is offline
Old 07-27-2010, 02:13 PM
  #48
Damn! Move over Einstein.
MulliganAl is offline
Old 07-27-2010, 03:34 PM
  #49
highvoltage's Avatar
Trader Rating: 145 (99%+)
amain has them instock right now
Thank you they have 2 right now in stock...
highvoltage is offline
Old 07-27-2010, 06:20 PM
  #50
kaisertrip's Avatar
Default LOL
That was a Copy and paste the link is below, don't want to plagiarize !!!! LOL
Got mine today Busy as a BEE!!!!
Old 07-27-2010, 09:49 PM
  #51
Trader Rating: 33 (100%+)
Got Mine today too.......
Sure is Fun assembling New Toyz
silversam is offline
Old 07-28-2010, 05:11 AM
  #52
Was your buggy in stock when you ordered or are some companies getting shipments earlier than the late Aug projected date.
Old 07-28-2010, 06:54 AM
  #53
Got it from A Main... canceled my Tower back order.
Old 07-28-2010, 11:32 AM
  #54
GAMBITX's Avatar
ohh today my 25t pinion and 44 spur gear have arrived! time to haul ass!
GAMBITX is offline
Old 07-28-2010, 01:07 PM
  #55
RC Corral's Avatar
Im putting in a tekin 2050 into my kit. can I use the stock pinion?
its 15T
RC Corral is offline
Old 07-28-2010, 01:23 PM
  #56
As of right now A-Main Hobbies has them in stock
Spencer G. is offline
Old 07-28-2010, 01:58 PM
  #57
its 15T
you can but I HIGHLY recommend you using between 18-20!
you will be significantly under geared with the 15
bohdi is offline
Old 07-28-2010, 02:00 PM
  #58
Leodis's Avatar
its 15T
I have a T8 2050 in my RC8Be and I use 18T or 19T for indoor tracks and 20T for outdoor tracks.
Leodis is offline
Old 07-28-2010, 02:23 PM
  #59
HuntersDad's Avatar
Trader Rating: 43 (96%+)
Actually the pinions you want to use are 14,15 or 16. Look at ANY team drivers setups and its usually 14 or 15 pinion. we run a 15 almost everywhere.
Kaisertrip, we are in irving also if you need any help.
vince and Hunter
HuntersDad is offline
Old 07-28-2010, 03:12 PM
  #60
Leodis's Avatar
vince and Hunter
All of the team drivers' set-ups I've seen using a 14 pinion are with the LRP 2800kv motor, not with the T8 2050. Please post set-ups of team drivers using a T8 2050 with 14 or 15 tooth pinions.
In my experience, the 16 tooth pinion is OK for indoor tracks, but you'll get passed by a well tuned nitro on an outdoor track using a 16 tooth pinion.
Leodis is offline
