Team Associated RC8Be Thread >
Old 03-04-2011 | 04:25 PM
  #3871
Originally Posted by jasons36
You really need to lengthen your red motor wire. With chassis flex and what not that's bound to be a problem.
Originally Posted by slash_me_up
Yeah, I just haven't done it yet.
Maybe it will be enough to just turn the end plate on the motor a bit so you don't have to solder?
Lars in Norway is offline
Old 03-04-2011 | 10:13 PM
  #3872
smkmoto's Avatar
How often do you guys clean your buggy? I spray it really good with the air compressor every time and wipe it down with a hard brush to get all the caked up dirt. Then spray a few more times. Pretty much I try to make it as clean as possible after every run. So far I have abOut 5 batter packs through her. What kind of stuff should I start doing soon? Also how do you get her shiny? Can't get it wet so yeah.... I would Post some pix up but I don't know how with iPhone 4 anyone elsE know how?
I spray mine lightly with Maxima SC-1 spray shine. It's made for motorcycles/ATV's, but works great on RC's too. I wipe off any excess, and after running it, you just blow out really good with air and lightly spray again. Makes my buggy look BRAND NEW! If you don't spray too much, it will actually dry. It also leaves a protective film on everything that repels water.
smkmoto is offline
Old 03-05-2011 | 05:15 AM
  #3873
Originally Posted by buggy8
agreed on the topic of bearings.
I was referring more to the rest of the car being washed. I have never washed my bearings in water but pretty much everything else gets hot soapy water.
I use a tupperware bowl with a lid on and rigorously shake it (not bearings). but of course I use an air compressor to remove all water then 99.9% alcohol to make sure no water is present. Good topic
You spend way to much time cleaning stuff!
agarabaghi is offline
Old 03-05-2011 | 05:23 AM
  #3874
jwmustang's Avatar
Any one know if this is good enough to blow out your car? I want something small and light weight.
http://www.walmart.com/ip/Wagan-500-...essor/10928425
jwmustang is offline
Old 03-05-2011 | 05:25 AM
  #3875
air compressors will blow dirt in places you can't get to. They are the devil.
Old 03-05-2011 | 07:19 AM
  #3876
orgnoi1's Avatar
Well I have been lurking on this post for a little while now... but officially I have joined the ranks as of today... my Be came in this morning via USPS from a seller on here...
orgnoi1 is offline
Old 03-05-2011 | 07:39 AM
  #3877
GreggW's Avatar
Check Harbor Freight. When I was there the other day. They had just air compressors pretty cheap.
Post pics when complete. Welcome again Ross!
GreggW is offline
Old 03-05-2011 | 08:20 AM
  #3878
Suspended
Welcome to the club Ross. I'm sure you'll be busy today messing with it
Thanks for this tip. Where would I get Maxima SC-1 spray? I'll take a look at pep boys today when I'm out.
Gregg. Great place. Cheap tools
I'm going to search for taht cheap air compressor your speak of as well.
Sarinexia is offline
Old 03-05-2011 | 09:01 AM
  #3879
buggy8's Avatar
try not to. I'd rather clean than buy new parts or wear out stuff racing
how exciting! welcome
this confirms my suspicions.
buggy8 is offline
Old 03-05-2011 | 09:05 AM
  #3880
buggy8's Avatar
Sold my rc8 w/ Tekno v3 and bought this. it seems like there are more options with the stock chassis etc. (for one, I can run a pinion over 18t)
I'm thinking I want a GRID mount simply because I've been hearing a lot of good things on here about them; beside that it looks well upgraded.
buggy8 is offline
Old 03-05-2011 | 09:44 AM
  #3881
orgnoi1's Avatar
Well my buggy came complete so I havent really done anything to it yet... I will be changing over to my CC MMM system probably tonight and then I will take some pics...
orgnoi1 is offline
Old 03-05-2011 | 10:25 AM
  #3882
smkmoto's Avatar
Check your local motorcycle shop. You may have to order it online. It is cheaper if you buy it by the case. Try www.rockymountainatv.com
smkmoto is offline
Old 03-05-2011 | 10:45 AM
  #3883
NoLuVv's Avatar
I bought a 4gallon compressor from Harbor Frieght a while back for 30-40 bucks. I went ahead and upgraded the hose to one that coils. Came with a bunch of attachments too. Runs like a champ.
NoLuVv is offline
Old 03-05-2011 | 11:59 AM
  #3884
per4m28's Avatar
nice...enjoy it!!
per4m28 is offline
Old 03-05-2011 | 12:07 PM
  #3885
117's Avatar
117
What is your ride height front and rear?
117 is offline
