Team Associated RC8Be Thread
#2376
Hey guys, I am getting ready to run my first electric outdoor season with my rc8be. The mains are 20 minutes, so lasting the duration is top priority.
So I am looking for some experienced racers to compare and contrast the following setups:
2650kv on 4S 5000 mah, 14T pinion
1900kv on 4S 5000 mah, 19T pinion
1700kv on 5S 4000 mah, 17T pinion
1350kv on 6S 3000 mah, 19T pinion
Thanks for any information/advice.
#2377
You must be running in the Nitro Mains.
You might also look at a 5500 pack. That would get you there with a little to spare.
#2378
you shouldnt have any problems with that setup at all, in fact he MMP is even a sensored setup! The SC8e RTR even comes with a MMP stock so someone at Team Associated must think it works well enough for 1/8 scale use.
#2379
I just picked this pack up, seems well made.
50C 5600mah
http://www.amainhobbies.com/product_...-ROAR-Approved
50C 5600mah
#2380
50C 5600mah
50C 5600mah
#2381
50C 5600mah
50C 5600mah
#2382
Yes, you can, but you will most likely not be able to run 6S. I tried an MMP with a Neu motor in my RC8Be, and it worked fine on 5S, but for some reason, it would not work on 6S. So I'd say, if you're going to stick with 4S or 5S, then you should be ok.
#2383
#2385
5/5/5 diffs
10 hole GHEA pistons
Stock front springs/OFNA yellow rear springs
25/25 shock oil
28/30 ride height front to back
Great car and this setup gives it a very neutral setting!
