RC10B4.1 FT/WC
Old 03-02-2012 | 10:52 PM
  #12331
rosko's Avatar
Originally Posted by FACTORYBUTNOT
The Worlds car comes with 30 degree caster blocks.
I'm not sure what springs Cav is running...I've heard other AE drivers are using the new AVID springs...
Im running the Kyosho Big Bore springs on standard v2 shocks...pricey to do so but worth it..
Thanks for the reply
rosko is offline
Old 03-02-2012 | 11:37 PM
  #12332
DaveW's Avatar
I have an original B4 'U' brace on my car... and know for a fact that the link mounts arent flush. Its close... but not flush. Ill add a pic tomorrow.
I opted to do this instead of two screws. I still like the body clips...
DaveW is offline
Old 03-03-2012 | 03:02 AM
  #12333
Originally Posted by Matt Trimmings
That diff has different outdrives and uses a standard bearing. It will work if you have a b4. If you have a b4.1 you will need the diff designed for the sc10, it uses metric bearings.
Wow dude your totally right. I built the diff up and put it in my B4.1 and now the dogbones are too short. If I get the FT CVD will it work or did I just waste 40 bucks. Thanks for the help, I wish they wouldn't put b4.1 in the description if it doesn't even fn fit, ridiculous. Thanks for the help Matt.
NYC Diesel is offline
Old 03-03-2012 | 04:57 AM
  #12334
Matt Trimmings's Avatar
Probably not, the bearings in the tranny case are different. It would work I'd you got an old tranny case, the one that uses standard bearings.
Matt Trimmings is offline
Old 03-03-2012 | 07:30 AM
  #12335
derekbsmith's Avatar
Default steer crank
stock steer crank. second 1 broke in 2 weeks....seems like brittle.
is this safe to use with this servo model? Savox SC1257tg
http://www.amainhobbies.com/product_...ank-Set-Silver
I have heard some rip apart servos depending up the servo.
thx!
derekbsmith is offline
Old 03-03-2012 | 07:47 AM
  #12336
I have heard some rip apart servos.
thx!
I would stay away from the STRC stuff myself. The Avid bellcranks are really nice...yes you dont have the servo saver but you arent going to get really reliable servo saver action with an all aluminum rack either.
Old 03-03-2012 | 08:14 AM
  #12337
ok thx! The part that always breaks is the upper saver part 9659. what is the fix then?
Old 03-03-2012 | 08:19 AM
  #12338
AErckidd's Avatar
I liked the Avid bellcranks too.. but make sure you have a very strong servo. I thought mine was strong enough, I put the bellcrank on and went out and not even three minutes into the pack, I destroyed the servo.
AErckidd is offline
Old 03-03-2012 | 08:22 AM
  #12339
Really...Dont hit stuff. I broke my first bellcrank last night and I was one of the first 20 or so to get a B4 when they were released at Cactus years ago.
Old 03-03-2012 | 09:33 AM
  #12340
Matt can you confirm that this is the diff I need :
http://www.toadzrc.com/associated-98...-diff-sc10.htm
Much thanks my man.
Old 03-03-2012 | 09:52 AM
  #12341
Much thanks my man.
That is the correct diff for any B4.1 or SC10 kits.
Old 03-03-2012 | 10:37 AM
  #12342
Blue Screw's Avatar
Good info bob...
as with the chub.. its a different feel most seem to like it more on a polished indoor tracks..
As for the tapping and set screw in the hubs.. it good idea just be careful u get the striaght.. if not ot will bind..
Alum front bulkhead again some like some dont like bob said cuts down on wear but also has a different feel.. its up to u... Thats why it seems the b4.1 works for anyone.. just put really the standard setup and work off of that for personal needs and feel...
Originally Posted by Bob Barry
Get an extra set of front bearings so you can make up a set of std front axles and keep in your box.
Get another U brace and leave it std. Shave the other one down. This way when you go from C hub Tower to A hub Tower, you can just switch U Braces and not have to worry about adding washes and then breaking a ball stud.
Some guys are cutting the wing mount nipples off and then tapping them so you can screw the wing onto the wing mount. I like this myself but haven't done it yet.
drill and tap the rear alum hubs and then put a grub screw against the hinge pin.
I also got the alum bulkhead just because I was tired of the plastic ones wearing out in 1 run. Yes I know the arm will slop out, but at least now it's only the arm and not the arm and the bulkhead LOL.
I also glued my servo saver. Just a drop and let it dry. That way in case of a big hit, the glue will break (hopefully LOL).
Other than that, I think you nailed all the stuff you wanna get.
Blue Screw is offline
Old 03-03-2012 | 11:25 AM
  #12343
jurquhart's Avatar
I just completed the build of my Worlds Edition B4.1 and it came with a weight but the instruction manual doesn't reference it at all. Where does the weight get placed?
jurquhart is offline
Old 03-03-2012 | 11:33 AM
  #12344
Just1More's Avatar
Remove the toe block, it goes between that and the transmission, directly under the 2 trans mount bolts, little dot on it facing the front or rear
Just1More is offline
Old 03-03-2012 | 11:36 AM
  #12345
gamedog1966's Avatar
behind the onboard toe and infront of the tranny case with the dot either facing the fromt or rear of the car
gamedog1966 is offline
