RC10B4.1 FT/WC
Old 02-29-2012 | 09:17 PM
  #12196
EvanAZ's Avatar
Got my 8mm chassis and converted it over, only took like 15 min. Took it out not really thinking it would make a big difference... well I am sold, this along with the Losi BB spring mod makes me want to keep it. To be honest I wanted a DEX210 but after doing those 2 mods this thing is on rails and I may just stay with the B4.1.
Anyone thinking its not that big of a difference... and is on the fence about doing the mods. Do it!!! it is worth the money. You can run your stock body for a while, I got a Finnisher body but its not painted up yet, so running the stock.
EvanAZ is offline
Old 02-29-2012 | 09:31 PM
  #12197
AErckidd's Avatar
I felt the same way and had to do the same thing with the bodies! The car handles great, and the Finnisher body just makes it look even better
AErckidd is offline
Old 02-29-2012 | 10:08 PM
  #12198
Just1More's Avatar
Saturday i raced with losi pink rear and orange front springs, finished badly due to popping a brand new RPM ball cup. Sunday while practicing i switched to associated silver rear and brown front, the car felt noticeably BETTER through the sweeper and turned just as well if not better in the infield. I will give the BB springs another shot in back to back testing(i run once a week, track is too far away), i'll try orange front and yellow rears but idk, seems i never have enough steering until i go to a shot front foam, then steering is twitchy and hard to stay on a line.
Just1More is offline
Old 02-29-2012 | 10:18 PM
  #12199
you had a very unbalanced combo for the BB springs.
Rule of thumb
Silver and Pink
Orange and Yellow
Red and White
I've never seen Pink work with anything but Silver.
Silver should be your starting point for std packs.
Pink for higher bite, Yellow for med, white for low bite
Orange and Yellow are what I normally run on a low bite rough surface.
Red/White combo is more for shorty pack or extremely loose conditions.
Try different combos and see how you like them.
Bob Barry is offline
Old 02-29-2012 | 10:21 PM
  #12200
Rule of thumb
Silver and Pink
Orange and Yellow
Red and White
What do you use for the spring perches to make Losi springs work? Do you need anything else?
PrestonG is offline
Old 02-29-2012 | 10:44 PM
  #12201
Wild Cherry's Avatar
Tech Legend
Mark
use the losi bb silver ft, 35w, #1, .060 internal, out on arm , middle on tower
losi bb white rear, 27.5w ,#2 .060 internal, inside on tower & arm
Wild Cherry is offline
Old 02-29-2012 | 11:37 PM
  #12202
Just1More's Avatar
Originally Posted by Wild Cherry
Mark
Hmm...Noticed Brian Shook was running that spring combo. Running stock seems to require more steering, my back end is too locked in with the yellows even, but i'll give this a try thursday at 4S if i can make it. What foam combo do you prefer? I've been running AKA red rear and PL closed cell front but will be going back to cut rear foams stuffed in the front, gold barcodes all 4 heavily sauced. Will back off the saucing on this new set of kicks though
Old 03-01-2012 | 03:10 AM
  #12203
idrummerboy13's Avatar
so if this pushes, why not try a proline foam in the rear and the open cell the rear golds come with and stuff in front? I cut down a little but the foam last so long in the front. Thats what we do here at island raceway in ny. its 70% clay the rest topsoil. Looks similar to cherries track.
ALSO! i notice my car slaps hard on the table with the silver and yellow tlr springs. also doesn't go fast at the sweepers to!....I loved dk yellow kyosho standard all around but I'm waiting on white and gold bb k to come. I notice they are way better then losi.
idrummerboy13 is offline
Old 03-01-2012 | 04:48 AM
  #12204
coaltrain's Avatar
Originally Posted by DirtRacer68
Here's one of my rides for the weekend.
What did you do/use to get the water effect on the back of your body?
coaltrain is offline
Old 03-01-2012 | 05:46 AM
  #12205
Tech Legend
Most use the Pro-Line blue for rear . For ft tire, use a full standard rear foam, no trim ...
* Tire grip before every run
* don't forget to vent outside of the tire on the rear tire when using close cell foam.
Old 03-01-2012 | 07:04 AM
  #12206
brent701's Avatar
Traxxas #3768 (Chris should have them in stock) Upper collars
TLR5095 Lower cups. Last I checked were on back order
You can use the cups that come in the traxxas kit but you will need to drill out the mounting hole a little to fit over the shaft eyelet.
If I sell my B44.1 without the BB springs I will have a extra set. IF you are going to be at One Hobbies this weekend
brent701 is offline
  #12207
Matt Ward's Avatar
Ill answer that question for you. I don't think he knows, the body was painted by Winning Edge Design.
Matt Ward is offline
Old 03-01-2012 | 07:13 AM
  #12208
Ya i should be, let me know.. How come you are selling the B44.1 i love mine, its like a bullet.. How much are you trying to get for it?
PrestonG is offline
Old 03-01-2012 | 08:46 AM
  #12209
njnewc's Avatar
For $20 shipped to your door I can send you alum collars that will allow you to use your stock tops and bottoms.
The picture shows the collars with a Losi bottom but they fit well on the AE bottoms... I can take pic's of them on all of my vehicles...
Attached Thumbnails RC10B4.1 FT/WC-updated-shock.jpg
njnewc is offline
Old 03-01-2012 | 08:55 AM
  #12210
jirish617's Avatar
For those of you running velcro on your bodies, have any of you just eliminated the rear tab that normally goes over the pin for the body clip? A buddy of mine bought a used b4.1 and they had it cut clean in the back with no tab, and in my eyes seems it would work well. I'm still using body clips but eventually that tab starts to crack off, my dad has velcro but still has the tab with no clip and it seems to slowly be cracking a bit too. I have a body being painted by a local guy and I plan to actually take care of it and thought about removing the tab to help it last a tad bit longer, any one else do this?
jirish617 is offline
