RC10B4.1 FT/WC
#4696
If your running regular foams, water does indeed breakdown the foams. With closed cells this isn't a problem, however, there's arguably only one set rear closed foams worth running now the AKA red closed cell. The others are much too hard for most outdoor applications. This soon will change as proline and JConcepts are producing softer closed cells. I run a tiny hole on the outside of the tire and a standard 4-40 size hole on the inner. Just don't dunk the tires in the bucket. Ideally, using a bucket with a brush glued to the bottom and filling the bucket to just under the bristles of the brush works great for 1/10 scale tires.
#4697
#4698
That's what I use to clean my tires is an old toothbrush.
I see people at the track using the brush in a plastic tub idea.
The only thing bad about using simple green on tires is they eat up the foams over time, just you have to be careful. I just use regular soap and water.
#4699
#4701
I have many new sets of the red AKAs, and the Blue proline closed cells, and the proline foam is just barely noticeably softer, not firmer, and appears to be better material when you look at them side by side together.
#4702
#4703
#4704
#4705
The setup from the worlds were posted on Team Associated website. Pretty interesting to see what way they went with the long chassis.
http://www.teamassociated.com/news/a...etups_Released
#4706
#4707
#4709
Look at this spinning wheel! Firm foam too! You know why? Because the holes are in the rims, and the foams are staying dry. LOL !
