RC10B4.1 FT/WC
Old 02-26-2012 | 03:23 PM
  #11986
racer1812's Avatar
Super Moderator
Originally Posted by fastharryDOTcom
Yep, but I have a standard B4, not a 4.1..
I looked at the manuals online and the lower arm mounts are different..but, I could be wrong.
As far as I know it should still fit.
racer1812 is offline
Old 02-26-2012 | 03:26 PM
  #11987
fastharryDOTcom's Avatar
Regardless, Everyone is sure the 8mm chassis is a direct replacement for a standard b4?..
I don't need anything else?
fastharryDOTcom is offline
Old 02-26-2012 | 03:28 PM
  #11988
ya need the battery brace also.
controlledchaos is offline
Old 02-26-2012 | 03:29 PM
  #11989
Ok its been a while and still no answer ,and nothing on ae site what was hartson running for set up at smak track for the jcon race ,thnx
blingy is offline
Old 02-26-2012 | 03:33 PM
  #11990
I'll get the conversion kit with the brace..Thanks
Old 02-26-2012 | 03:34 PM
  #11991
brent701's Avatar
It will fit
Yeap
Will fit also. You will need the +8mm battery strap like said..
brent701 is offline
Old 02-26-2012 | 04:26 PM
  #11992
Matt Trimmings's Avatar
Matt, I don'[t think you can put the weights in between the rear arms on the B4 like you can on the worlds...
It fits in them all, I have been putting weight back there for years.
And all you need is the +8mm conversion, everything else bolts right on.
Matt Trimmings is offline
Old 02-26-2012 | 04:46 PM
  #11993
just got done with updating my buggy with the +8 chassis and new bulldog body. Got the setup i want now i just need to get the money for that tekin setup and possibly the threaded shocks but was told they dont make a difference and my car will be all set.
Attached Thumbnails RC10B4.1 FT/WC-car.jpg
chancejeff is offline
Old 02-26-2012 | 06:22 PM
  #11994
Jake S's Avatar
weight fits, but not the ballast weight in the b4 rear toe block. the 4.1 block is needed for the ballast to fit properly.
which even if you have the b4 you can get the 4.1 toe block set, which is nice because you gain extra adjustment of other blocks then just 3.0*
Jake S is offline
Old 02-26-2012 | 06:25 PM
  #11995
flippz's Avatar
it looks good.
the threaded shocks may not make you fast in the race track, but at the pits and the house will be a lot fater. the rebuild is much easier and quicker. they do feel a bit better also. i had rtr and ran it for a while but the threaded shocks was a upgrade i did and liked it much.
flippz is offline
Old 02-26-2012 | 06:30 PM
  #11996
flippz's Avatar
can anyone tell me why the w.e. b4.1 does not come with the v2 slipper hubs? has the solid hubs and not vented
have the build complete. trying to figure out a good setup for the car. buikd was easy and smooth. had every thing i needed (even had 1 extra washer). car looks great and hope it is as fast as it looks.
thanks
scott ross
flippz is offline
  #11997
Luvofgti22's Avatar
Originally Posted by brent701
wow went back 11 pages. That doesn't show me you really gave it any thought to do some research of your own.
Here
http://www.rctech.net/forum/10092874-post8971.html
I bought a B44.1 and read the whole thread.
I bought a B4.1 and started at the front and browsed through the thread.
I bought a SC10 same as above
I Bought a SC10 4x4 same as above.
I do not have the free time as you may think to read it all. I am very competitive and like to know as mush as I can about what I am racing. So taking the extra time is worth it to me.
I have no problem helping people. I am sorry if I came across as a d-bag. It helps for the person asking the question to at least have tried to find it on their own. I did.
No biggie though. I hope you get the parts you are looking for and it works out for you.
If the TLR5095 parts are not in stock. There is a way around it which is posted in the SC10 thread.
I run Losi BB on front/back of my B4.1, B44.1 and SC10
Soooo ....
What parts do I need?
Luvofgti22 is offline
Old 02-26-2012 | 07:13 PM
  #11998
man am I having some rotten luck with speed controls. 2 weekends.... 2 bad LRP SXXv2's.
I'm thinking it may be time for a switch...
Bob Barry is offline
Old 02-26-2012 | 07:16 PM
  #11999
B.A. Racer's Avatar
I've had mine for a whole year and have NEVER had a problem with it
B.A. Racer is offline
Old 02-26-2012 | 07:22 PM
  #12000
Originally Posted by B.A. Racer
I've had mine for a whole year and have NEVER had a problem with it...since I switched from tekin because the lrp feels so good
performance wise, no doubt. Love my LRP. But last week, cracked board and this week the buttons don't work on my replacement. Press and hold mode... nothing. Set either. I did get lucky and get the Speedo to reset into default one time. It's almost like the buttons just don't work anymore. So now I have my only working speedo stuck in blinky mode....
I'm going to send em both back and get them repaired..... but this just flat out sucks...... 2 weekends... 2 200.00 speedos.
