RC10B4.1 FT/WC
Old 02-11-2012 | 10:20 AM
  #11236
Wild Cherry's Avatar
Tech Legend
Originally Posted by JoshCorti11
wow that sucks I have been hearing alot of things about the new worlds car missing parts. I think associated is getting lazy
or
The missing parts fell under the table, ect ....
Wild Cherry is offline
Old 02-11-2012 | 10:24 AM
  #11237
Tech Legend
Originally Posted by mxracer458
love to see some reedy setups!
I discuss with our 2 local Ae drivers that made the open A main ...
Only thing they changed from the current set-up were to a bit thicker oil , 32.5 ft , 30w back & the modified slipper pad I have posted about earlier...
Old 02-11-2012 | 11:25 AM
  #11238
racer x 1's Avatar
but what is the current set-up they are refering to?
racer x 1 is offline
Old 02-11-2012 | 11:27 AM
  #11239
Tech Legend
The set-up I posted a bit back , except they use K-springs instead of losi.
If you wish , send me your E-mail & I send you a copy of the set-up.
Old 02-11-2012 | 12:22 PM
  #11240
JEFFs SC10's Avatar
I picked up a cherry 1 mo old FT b4.1 this morning, I quickly threw my electronics in and took it out up n down the street. Wow I love this thing, Ive seen the light. Feels like it needs more gear, Im running 74/28 with timing,boost and turbo ( novak ss 17.5), motor is not even close to hot.
JEFFs SC10 is offline
Old 02-11-2012 | 12:27 PM
  #11241
Tech Legend
Enjoy your new ride ...
At Trcr the fast b4's are using 32/75 no boost on 17.5
Old 02-11-2012 | 12:32 PM
  #11242
idrummerboy13's Avatar
if you don't mind can u send it here
idrummerboy13 is offline
Old 02-11-2012 | 02:19 PM
  #11243
bshookup's Avatar
Not sure this is the one, but it has worked really well for me: http://www.rctech.net/forum/10139016-post9412.html
bshookup is offline
Old 02-11-2012 | 03:27 PM
  #11244
mxracer458's Avatar
interesting,plastic rear arms and carbon fronts?
mxracer458 is offline
Old 02-11-2012 | 03:37 PM
  #11245
racer1812's Avatar
Super Moderator
more rear grip, since he says the track was med. traction...would be my guess
racer1812 is offline
Old 02-11-2012 | 03:55 PM
  #11246
That's more or less what I run right now with the exception of 35wt oil with 1 piston. How does that differ from 30wt and 2 piston on the track? Only other thing is I run 2.5 inboard toe and no shims under rear inner ballstud.
Bob Barry is offline
Old 02-11-2012 | 04:02 PM
  #11247
racer1812's Avatar
Super Moderator
FYI for those new to this thread or don't use the search button much. When you run the carbon rear arms make sure you clearance the outer web for the CVA, it doesn't rub much but it's enough to catch the pin retainer, glued or not. Don't ask how I know..
Old 02-11-2012 | 04:10 PM
  #11248
itchy b's Avatar
Got the kit to convert my v2 b4 shocks to bladder style yesterday
It has small and larger foam pads in there which i assume are to fit inside the bladder in the cap.
Are these useful and what would i expect to feel using these vs without?
itchy b is offline
Old 02-11-2012 | 04:38 PM
  #11249
I have a rtr sc10 ( don't bash,have a top notch backyard track as well as a lhs I race at about once a month) and recently picked up FT B4.1. For the buggy I have a Reedy RADON BRUSHED 30,000 RPM motor with a speedpack 2s 5300 mah lipo. I am wondering how the speeds of these two cars will compare to one another. I have drivin buggies before so I know how they handle but I have never pushed them like I have the sc10.
Thanks,
Chad
cw41 is offline
Old 02-11-2012 | 05:40 PM
  #11250
JEFFs SC10's Avatar
Thanks buddy, I ended up putting my savox 1257 in, I like to have speed in my steering.
Hoping they have bigger pinions at New Red, I'm just using a crap Novak SS 17.5 motor for now just to get it running. I'll be running pretty much all day to get used to it and dial it in. basically I have a factory setup with weights in the triangles and 1/2 oz under the rear tower.
so what's the consensus on 17.5 motors, Revtech, Reedy Sonic? I plan on running blinky and then if they have a super stock I'll run that with boost.
What is the science behind the rear wings? I see you can cut out for less downforce, what does everyone pretty much run. I'm going to experiment and see what works.
