RC10B4.1 FT/WC
Old 11-04-2011 | 03:06 AM
  #7126
Teufel Racing's Avatar
Nice pic,
hadn't noticed that until I looked closer at the pic. Might be a good thing to run. Wonder if you can lock it out like using some CA in the plastic setup, only not using CA?
Teufel Racing is offline
Old 11-04-2011 | 05:12 AM
  #7127
Jmuck69's Avatar
Originally Posted by Blue Screw
Have any of you seen or noticed in pics the alum. front steering linkage that factory guys are testing? i noticed on cavs and mayfeilds car before but now on testmans..
Hopefully it uses ball bearings to eliminate the slop.
Jmuck69 is offline
Old 11-04-2011 | 05:34 AM
  #7128
MiCk B's Avatar
Alu steering, would it be something similar to this?
http://www.cmldistribution.co.uk/cml...tId=0000004405
MiCk B. :-)
MiCk B is offline
Old 11-04-2011 | 06:35 AM
  #7129
Matt Trimmings's Avatar
MiCk B. :-)
That's it..it's a one piece unit so you don't have to worry about a servo saver.
Matt Trimmings is offline
Old 11-04-2011 | 07:31 AM
  #7130
Wild Cherry's Avatar
Tech Legend
I use ball bearings on my steering rack...
Wild Cherry is offline
Old 11-04-2011 | 07:55 AM
  #7131
RCmayor's Avatar
Originally Posted by air8
Agreed. The wd-40 can with straw attached should disappear. Plus there is no way to keep the can from spraying if something is on top of the it. At lrast put a freakin lid on the thing. Lol.
Some places have this can. Much nicer for spraying an even layer. Not sure why this came up in an electric thread though, mostly for gas stuff.
http://www.wd40.com/products/wd-40-big-blast/
RCmayor is offline
Old 11-04-2011 | 08:12 AM
  #7132
mjk1210's Avatar
Been running the alu. rack since last spring on sct and t4. love it. much more direct feeling and no more "oh crap, my car won't turn, I wonder if the servo save backed off". Or if you glue it "oh crap I just hit a tube, hope I don't have to replace my servo saver"
mjk1210 is offline
Old 11-04-2011 | 08:20 AM
  #7133
Jmuck69's Avatar
I meant in the akerman plat to servo arms connection. that is where most of the slop occurs.
Jmuck69 is offline
Old 11-04-2011 | 08:23 AM
  #7134
Tech Legend
Gluing the saver on the plastic steer rack is more better than a aluminum version .
The plastic flex's & saves the servo instead....
Old 11-04-2011 | 08:27 AM
  #7135
Tech Legend
Should edit your post then .....
You think the aluminum ones would not have
any play between the parts ?
Cus
they have the same play as the plastic if you did not know ...
Old 11-04-2011 | 08:47 AM
  #7136
joelwhite's Avatar
Its a kinwald thing, he has been using them for a while now. Here is his 2010 cactus car, when he was still with X-Factory
joelwhite is offline
Old 11-04-2011 | 09:52 AM
  #7137
Midnight's Avatar
On Brent theilke setup it calls for ghea #3 rear piston. What regular ae piston would compare? Also he calls for 3/4 oz behind servo? How do u put weight behind the servo? Pics would be nice. Lol
Midnight is offline
Old 11-04-2011 | 10:00 AM
  #7138
Jmuck69's Avatar
Should edit your post then .....Or not because I really don't care.
Cus
Jmuck69 is offline
Old 11-04-2011 | 10:46 AM
  #7139
aeRayls's Avatar
Use a #2 piston or a #3 drilled out to 55.
Put the 3/4 oz in front of the servo.
aeRayls is offline
Old 11-04-2011 | 11:25 AM
  #7140
It is actually placed behind the servo (if you have room) or in front of the battery.
