RC10B4.1 FT/WC
#6721
#6723
Hello Im a new owner of a B4.1/T4.1 and im going to race pretty casual. I been looking over the boards but hard to find a definitive answer on what a good esc/motor system to use that wont break the bank? Im not one to go super cheap but the little I will be racing I really dont want alot of money tied up into two expensive systems. Any bargin options? Thanks.
#6726
Ok guys I need some insight. I recently reassembled my transmission. The diff is set correctly and broken in. I was trying to set the slipper using the method of holding the rear tires and using short bursts of throttle. The front end will not come off the table and sounds like it's slipping. I'm using the new V2 setup but had also tried the older setup and both had the same outcome. I've tried tightening down several times and the pads have no glazing.
What else could it be?
#6727
#6729
#6731
#6732
Take the slipper back off and make sure everything was seated properly and basically start over...if the diff is right, and not barking on the bench test, then I would just start all over again from the beginning. It's like, what's left?
#6733
#6734
Whats it sound like when you fully tighten the slipper, something has to give or the motor stalls out if the wheels aren't pulling up.
#6735
I already had tore everything down and didn't find anything.
