RC10B4.1 FT/WC
Old 08-28-2011 | 07:17 PM
  #5506
Jmuck69's Avatar
Originally Posted by bmsgangster
I use simple green mixed with wd-40 it makes it look brand new!
I'm currently using Simple Green and it's making it look dull. So the WD is the trick? Do you mix and out into a spray bottle?
Jmuck69 is offline
Old 08-28-2011 | 07:18 PM
  #5507
Matt Trimmings's Avatar
Originally Posted by Jmuck69
What are you guys using to clean up the plastic between rounds and to give it the deep black look. Kalgard Prep & Shine, silicone spray or other?
I have always used WD-40.
Matt Trimmings is offline
Old 08-28-2011 | 07:30 PM
  #5508
jamminjim's Avatar
Does the WD40 make things stick to the chassis etc? I find Simple Green dries well and leaves very little residue.
jamminjim is offline
Old 08-28-2011 | 07:32 PM
  #5509
Make things stick? I have never had an issue, i just put a little bit on one of the upgrade brushes and brush the car off, then wipe the chassis with it.
Old 08-28-2011 | 07:38 PM
  #5510
Actually WD makes the dirt stick less. Sprint car teams use to spray the cars down with wd to prevent the clay from sticking to the car. I tried it on my street stock before and it work well.
JW91 is offline
Old 08-28-2011 | 07:45 PM
  #5511
I mix it in a small bowl brush it on with a paint brush then wipe off with a towel, it works great makes it look new!
bmsgangster is offline
Old 08-28-2011 | 08:11 PM
  #5512
Wild Cherry's Avatar
Tech Legend
Wd or green pales compared to Endust or even Pledge .....
Wild Cherry is offline
Old 08-28-2011 | 11:11 PM
  #5513
mellow's Avatar
Lovin this longer chassis. TQed and won the main today
mellow is offline
Old 08-28-2011 | 11:40 PM
  #5514
idrummerboy13's Avatar
i use the simple green and wd40 ,about 80 percent simple 20% wd sometimes just straight wd40 but always use a rag and wipe the stuff off after i use car detailer which makes every part look brand new! i use pledge of the chassis and the bodys when i use it on the car it just covers the dirt you have to wipe it...
idrummerboy13 is offline
Old 08-29-2011 | 04:23 AM
  #5515
t4mania's Avatar
Got my long chassis from Brent on Saturday. Excellent cutting & gluing done on a brand new chassis. If you need one give Brent a call, you won't be sorry..
t4mania is offline
Old 08-29-2011 | 07:18 AM
  #5516
916bdogg's Avatar
Talking AE Is Killer Of All......
BRING IT THURSDAY !
916bdogg is offline
Old 08-29-2011 | 08:43 AM
  #5517
bilster44's Avatar
That's good stuff Trevor! We'll see ya's on Sunday at your place.
bilster44 is offline
Old 08-29-2011 | 09:08 AM
  #5518
rednck21's Avatar
Spray with simple green, clean it with a brush then blow it off with air. If you want it to shine do the same thing with pledge afterwards.
rednck21 is offline
Old 08-29-2011 | 10:00 AM
  #5519
Tech Legend
No body uses WD anymore ....
Use the green to clean though, very good for that ,
remember finish with Endust ....
How to use Endust or Pledge
*spray on ride
* rub ride down with toothbrush
*use air hose to blow off excess
* finish with a clean towel....
The wax will help your car stay smooth , the Endust works so good ?
Your car
will look just like a brand new ride ...
Old 08-29-2011 | 10:10 AM
  #5520
bilster44's Avatar
Commercial line orange scented Fantastic does a great job with no residue.
