RC10B4.1 FT/WC
Old 06-18-2011 | 07:59 PM
  #3301
Dannyrevs's Avatar
Default Bearings
How long do bearings usually last? My car has maybe 20 batts ran through it now and today seized a outdrive bearing. The other side bearing felt gritty. Also could someone tell me the easiest and correct way to remove these bearings they seem pretty stuck in place and do not want to come out.
My friend has a T2 ST and said he is on his original outdrive bearings. My kit was brand new a few months ago.
Did I just get unlucky?
Dannyrevs is offline
Old 06-18-2011 | 08:29 PM
  #3302
dirtdustingdavo's Avatar
I'd say very unlucky, I only replace my out drive bearings when I'm going to a state or national event...which isnt very often these days.
have you tried using a hex driver to tap them out from the other side?
dirtdustingdavo is offline
Old 06-19-2011 | 08:52 AM
  #3303
Dannyrevs's Avatar
Thanks for the reply. Actually I found out today a easy way to get the outdrive bearings out of the 9826 tranny case. Is to use a 1/4" socket driver put it in the outdrive hole from the outside of the case and push the bearing out.
The big question is how to remove the Top shaft bearings since you cannot access the bearing from the outside on one half of the tranny case.
Anyway replacing all tranny bearing including idler gear bearings. Do not want this to happen again. Had I not noticed the problem right away I was heading for a motor melt down real fast.
Old 06-19-2011 | 09:50 AM
  #3304
Cpt.America's Avatar
Originally Posted by Acill
How about the Losi 22 shocks? I hear the fit the 4.1 fine. Been thinking of getting a set.
How the heck would those huge things fit?
Cpt.America is offline
Old 06-19-2011 | 10:35 AM
  #3305
that's what she said...
GuiltyByAssoc is offline
Old 06-19-2011 | 10:38 AM
  #3306
916bdogg's Avatar
Thumbs up AE Is Killer Of All......
all you need to do to the AE springs is use paint remover and strip them then when you set them up on the shocks you can turn them till they WON'T RUB .
I just did this to Mine and even Layed down the best Run I've Made So far @ My New Home Track .
www.lsrspeedway.com
916bdogg is offline
Old 06-19-2011 | 01:05 PM
  #3307
Default servo warm
i have a xp 1015 and after i come off the track from a heat race the servo case is warm is that normal and would it cause it to glitch?
Bubonic-X is offline
Old 06-19-2011 | 04:34 PM
  #3308
R/C Tech Elite Member
Hey Guys, I have a question for you all.. I received some Blue FT front B4 axles in a parts lot, and when I went to try and mount them up, noticed they were like an 1/8 per side narrower then the std steel ones I have been using. So, which are right? I can shoot some pics if that will help
flame56mx is offline
Old 06-19-2011 | 05:10 PM
  #3309
So my 1st time at West coast raceway with the b4.1 ended badly; but I had so much fun trying to keep up with the slew of 22's (it seems 7 out of 10 bugggies are the 22's). Some before and after pics.
Attached Thumbnails RC10B4.1 FT/WC-b4.1-b.jpg   RC10B4.1 FT/WC-b4.1-c.jpg   RC10B4.1 FT/WC-ouch.jpg
Old 06-19-2011 | 05:23 PM
  #3310
OUCH--Dang, how did that happen??
Old 06-19-2011 | 05:28 PM
  #3311
that looks like he smacked something at speed dead on. It happened to me before....identical carnage
evilllempire is offline
Old 06-19-2011 | 05:49 PM
  #3312
Mistake 1- Let my friend drive the b4.1, he smacked into a sct or vice versa and hit the concrete barrier broke the bulkhead.
Mistake 2- Decided to upgrade to SCTR aluminum bulkhead instead of the stock plastic one.
Mistake 3- There was a speed trap setup at the end of the front straight, so instead of watching the car, I was watching my speed (got up to 26mph!)..bang!!
The alum. bulkhead survived w/o a scratch, chassis didn't. I've since changed back to the plastic AE bulkhead, since alum. also added weight that messed up the jumps...
Old 06-19-2011 | 06:00 PM
  #3313
bds81175's Avatar
Moderator
Post some pics. I'm curious to see what you are talking about.
bds81175 is offline
Old 06-19-2011 | 07:44 PM
  #3314
aeRayls's Avatar
If they are 1/8 in narrower, you might have the T4 axles on the car. Other than that I dont know what it could be without pics.
The Blue alum axles are plain junk anyway, save yourself a DNF and dont put them on. Theres a really good reason ae now makes Ti and Steel front axles like those.
aeRayls is offline
Old 06-19-2011 | 07:46 PM
  #3315
Matt Trimmings's Avatar
The blue aluminum axles are for the buggy only. The wider ones are for the truck. Is it possible you have been using the truck versions?
Matt Trimmings is offline
