RC10B4.1 FT/WC
#4805
Can someone tell me the typical sensor wire length for a B4.1? I don't have my car in front of me to measure.
So for the most part, are these chassis mods holding up? Has anyone tried lengths other than what was run at the worlds? I thought I remember reading the full length T4 chassis was still within allowable wheelbase limits, so it seems like there would be some room to work with.
#4806
The full length T4 chassis is too long to be useful. It would make it lazy. The 8mm additional length is the happy medium.
#4809
Ive had 3 b4 ft over the last couple winters. I'm looking at getting a rtr b4.1 and using the stock motor esc. Any issues with the stock esc burning up
Also with the longer chassis. Does the b4 bulldog still work?
Also what parts are extra upgrades on the ft over the rtr
#4810
Hmm 11" seems like it would leave some slack. I was thinking 150-200 would have been more like it. I'm thinking of making an order with tq wire and they have 25mm (~1") increments
#4811
#4812
Well I did the chassis mod thing over the week and I had very good results from previouos races. First time ever I did 13 laps at our track. Yeah, the faster 3 at our track always seem to do 13 lasp but not me, not until I did this limo chassis. Car off the bat pushed, but for me I moved the battery foward and added 25 deg castor blocks, adjusted ride height/camber again, and bamm. It just worked. The longer chassis for me just seemed to be able to drive faster in and out of corners without the car getting upset.
Well, thats my .02
I used a hack saw to cut straight lines and Med Ca to glue it back together then the left over peices as braces. Held up all night and practices. I did break it once in practice the first time out but I cased a pipe off a big jump onto a spike. So would've broken anything. Glued it back and been solid since. Measured the wheelbase afterwars and it was at 284.162mm. Close to a 22 at 285mm. I'm just the average Joe doing this but worked for me.
Bulldog body from a RB5 fits ight.
Well, thats my .02
#4814
Your chassis broke because you didn't brace it correctly. don't worry about bracing the bottom... just the sides. If you look at the vertical pieces of the chassis in your picture, you can see the bracing only covers like 1cm on both sides of the cut line. Make a long skinny piece that goes lengthwise along the vertical piece of chassis, so you have like an inch on both sides of the cut line. The bracing you did there wont cut it.
#4815
