RC10B4.1 FT/WC
Old 04-21-2011 | 08:06 PM
  #2551
bds81175's Avatar
Moderator
Sounds like May 15th will be our first outdoor race at Full Throttle in Foley Minnesota. By the way ModTurtle, that was an awesome clip. Dudes got some awesome range and a crazed imagination.
bds81175 is offline
Old 04-21-2011 | 08:08 PM
  #2552
bds81175's Avatar
Moderator
Have you guys followed the thread about shock o-rings? Anybody on here experimented with any other o-rings besides the AE? The X profile ring seems like a great idea.
bds81175 is offline
Old 04-21-2011 | 10:54 PM
  #2553
TheModTurtle's Avatar
I've personally never had a problem with the AE o-rings... I guess once I do I'll give the 'x'-rings a try!
Yeah, that clip was great and I love John Williams' work so...
TheModTurtle is offline
Old 04-21-2011 | 11:51 PM
  #2554
RA99GT's Avatar
I use these o-rings from McMaster-Carr. They last a very long time before they show signs of leaking
RA99GT is offline
Old 04-22-2011 | 08:38 AM
  #2555
And they come in packs of 100?!?! Are they an easy fit? Same dimensions as the AE ones?
Old 04-22-2011 | 08:41 AM
  #2556
Jmuck69's Avatar
The new SC10 4x4 uses the x-rings.
Jmuck69 is offline
Old 04-22-2011 | 08:48 AM
  #2557
RA99GT's Avatar
They are the exact same size as the stock Associated ones, a standard AS568A-006 O-ring. Just select the correct AS568A dash number and you can try different materials and durometers if you want.
RA99GT is offline
  #2558
Thats awesome! I'll definitely be coming back to that link! That is a GOOD price
Old 04-22-2011 | 08:50 AM
  #2559
RA99GT's Avatar
true. but i think they are a different size than the -006 o-rings used in the other 1/10 shocks.
RA99GT is offline
Old 04-22-2011 | 08:57 AM
  #2560
Jmuck69's Avatar
I was referring to was that this seems to be where oring technology is going. Hopefully this become standard in all AE lines and future versions of their shocks.
Jmuck69 is offline
Old 04-22-2011 | 09:02 AM
  #2561
RA99GT's Avatar
Ah. I agree then Quad O-rings are a standard off the shelf item. I wonder why AE didn't use them in the first place?
RA99GT is offline
Old 04-22-2011 | 09:07 AM
  #2562
Because if they waited to upgrade them in a later kit they can justify an extra 5 dollars on the price
Old 04-22-2011 | 09:13 AM
  #2563
Wild Cherry's Avatar
Tech Legend
Default O-rings
Maybe Ae thought saving a few cents is not worth a big lost in performance.....
Wild Cherry is offline
Old 04-22-2011 | 12:35 PM
  #2564
mdwaeracer's Avatar
The kyosho springs being used on b4's, is it the big bore or regular springs. What colors for front and rear, also what weight oils are being used?
mdwaeracer is offline
Old 04-22-2011 | 12:51 PM
  #2565
Jmuck69's Avatar
You would use the regular springs. Color would be orange or Yellow fronts and cobalt blue rears. Shock oils would be the same. What the springs offer is no rubbing against the bodies and more progressive spring rates. This will help reduce chassis slap. Also note that Durango springs will work as well. i have them currently mounted up and do not rub the bodies what so ever. i will be trying them out tomorrow.
Jmuck69 is offline
