RC10B4.1 FT/WC
Old 01-17-2013 | 10:01 AM
  #27466
Wildcat1971's Avatar
I have had an issue with all of my AE 2wd cars. The rack is binding when I tightening the top plate. If I back the screws off 1/2 - 1 turn, then it goes away. I dont really like the idea of backing screws off on parts that take a beating. I have tried to visually inspect the issue, but I do not see any wear marks on the chassis. I assume the upside down screws that mount to the rack are binding on the chassis and pressing on the rack. I could tighten those screws a little more more clearance, bu then the rack would bind from over tightening. Any thoughts?
Wildcat1971 is offline
Old 01-17-2013 | 10:03 AM
  #27467
Yes it can vito. The cost is about $170 in new parts.
Old 01-17-2013 | 10:26 AM
  #27468
really? what's the deal with $170??
shagnat is offline
Old 01-17-2013 | 10:27 AM
  #27469
vito's Avatar
can i get a list of the parts to upgrade to a b4.2 thanks so i can go to the lhs with it
vito is offline
Old 01-17-2013 | 10:34 AM
  #27470
Tradin Paint's Avatar
You can get it with about 30 seconds of work
Tradin Paint is offline
Old 01-17-2013 | 10:37 AM
  #27471
njnewc's Avatar
Your LHS should know... Or go to teamassociated.com and look at the list of new parts...
njnewc is offline
Old 01-17-2013 | 10:51 AM
  #27472
BB Shocks $100 (ASC91314 / ASC91316 )
Alum rack $25 (ASC9679)
Front And Rear Hexes $20 (ASC9890,ASC9891)
Hex Hubs $12 (ASC7496,ASC9880 )
Hex Wheels $12 (ASC9691 ,ASC9696 )
VTS Slipper $15 (ASC91175 )
New CF A hubs $12 ish (ASC9917)
New Towers $10 ish (same as old part number, this is a running update)
Total $200+ (amain approx pricing, way more at the LHS)
Old 01-17-2013 | 10:56 AM
  #27473
vito's Avatar
thanks
vito is offline
Old 01-17-2013 | 10:58 AM
  #27474
66Racer's Avatar
Thanks for the diff info guys
66Racer is offline
Old 01-17-2013 | 01:10 PM
  #27475
LosiRacing7607's Avatar
Anyone have problems with blowing out the rear inner hub bearing? I have all stock parts except Jconcepts axle nut that tightens while driving. Other then that I take care of my car and have had this happen to a , losi 22 and hpi blitz. Any better bearings to put in there that won't kill the bank? Or a fix.
Like I said, everything is factory stock and all the parts are togeather right. B4.1 worlds
LosiRacing7607 is offline
Old 01-17-2013 | 01:13 PM
  #27476
Use Avid bearings in the hubs. I dont know what brand you are using but the AE bearing or craptastic and explode. I had the same issue, then I put some avids in and fixed.
Old 01-17-2013 | 01:34 PM
  #27477
njnewc's Avatar
Put some locktite on the outer bearing race before you put it in. It will secure it alittle better. Boca Bearings are good too...
njnewc is offline
  #27478
huzzler's Avatar
Honestly you would be better off buying a b4.2 kit and selling the parts you dont need on e-bay. That's what I plan on doing.
huzzler is offline
Old 01-17-2013 | 01:38 PM
  #27479
Razathorn's Avatar
Panther sells tubes of 10 for $10. That's what I use. I've blown a lot of those out recently. A LOT. Probably like 15 (tranny, front wheels, rear axles.)
I think AE might have had a bad batch.
Razathorn is offline
Old 01-17-2013 | 01:41 PM
  #27480
Tranny bearing? Outdrive bearings? I think a tube of avids are $10 also.
