RC10B4.1 FT/WC
Old 01-03-2013 | 06:27 PM
  #26821
Wild Cherry's Avatar
Tech Legend
Originally Posted by dr_m_james
I found the problem. The pictures that show the turnbuckles are not drawn to scale.
apologies,seems I quoted the specs for the T-4 by accident..
Wild Cherry is offline
Old 01-03-2013 | 06:48 PM
  #26822
Jerm13's Avatar
Originally Posted by Wildcat1971
you went outside on the hub in the rear? C hub or A/B hub. But outside on the A hub is pretty long.
A-hub? I say that as a questin cuz it has the stock plastic ones. Everyone points and laughs until I lay it down. Best finish I can muster up is a second so far.
Jerm13 is offline
Old 01-03-2013 | 06:56 PM
  #26823
BRSracing's Avatar
Originally Posted by LOSI123
Can someone tell me if the Jconcepts 6" high down force wing will clear the wheels under full suspension compression, I wanted to order some if it does
I think all the wings rub under full compression, but it does not create an issue. My Jconcept wing rubs, but its not like they last long anyway
BRSracing is offline
Old 01-03-2013 | 07:00 PM
  #26824
Just1More's Avatar
Originally Posted by Jerm13
To tell you the truth, I dont think it has any limiters on it. Just the good old blue ones with the pre load clips. I got a set of V2's coming with big bore springs.
limiters go under the piston, inside the shock body. Style of shock doesn't matter there, but you'll like the V2's overall
Just1More is offline
Old 01-03-2013 | 07:05 PM
  #26825
BRSracing's Avatar
Originally Posted by LosiRacing7607
Has anyone had problems the rear turnbuckle hitting the new BB shock body's with the recommended spacers? I do have my rear hub forward but I still can't beleave my rear flexes 3/8" to hit the shock body.
I took out top spaces and shaved shock tower and seemed to fix this issue.
Yes we do have one bigger jump at my track and when over jumping it can be a harsh landing. Just shave the top tower and save you some problems.
You can also use the carbon hub towers. Associated makes the A and B tower in carbon now as well as the c. I used the C tower with the shaved rear brace, but for me I did not like the feel. I put the carbon A tower on with shaved shock tower and spacers on the bottom little to no rub now. I ordered spare shock bodies and lower caps as well for when i want to make them look all new again.
Old 01-03-2013 | 07:06 PM
  #26826
DaveW's Avatar
DaveW is offline
Old 01-03-2013 | 07:08 PM
  #26827
ray_munday's Avatar
The JConcepts 0122 6.5" Hi-Clearance Wing clears the tyres under full suspenson compression.
http://www.jconcepts.net/store/index...roducts_id=496
ray_munday is offline
  #26828
3srcracing's Avatar
So I finally got the rear end of my buggy locked down. So much so that it pulls the front end off the ground on the straights and elevation changes. Look at my set up and tell me if I am just wierd or its close to what some of you are running. I just want to see where I stand to people who have been running 1/10 buggy for more than 2 months. Keep in mind this car was an B4 RTR that is now in the upgrade as I break it stage.
Front
35 wt oil, #1 pistons, middle hole on the tower, inner on the arm
camber link inner on the hub and inner on the tower with 1 washer
2* camber with soft JC 4 rib tires open cell foams
Rear
30 wt oil, #1 pistons, inner hole on the tower, inner on the arm
camber link on the outer hol of the hub, inner hole on the u-brace with 3 washers
1* camber, rear tires are now slicks, were M4 Fuzzies.
I am running a gear diff with 3k, 10.5 motor, RS Pro, 1.5 oz behind the battery and a full size pack.
I like the way it feels now. I can run it in hot and she will stick as long as Im in the groove. The track is extreamly high bite so everyone is running worn out bar style tires to slicks. Fastest lap is a 13.7 in a 4wd Buggy. My fastest seems to be a 14.7 and I average about a 15.8 for a six minute qual. If I can get a little more consistant, I my just end up with a win.
Anything look wierd to yall?
Know wonder you are pulling wheelies I dont think you could do anything else to get more traction.
3srcracing is offline
Old 01-03-2013 | 07:29 PM
  #26829
Jerm13's Avatar
I know where they go, I just didnt see any of them in there. I got the V2's just to make the re-building esier. And it looks a little less getto IMO.
But it is fun to beat the guys who show up with the best of everything, latest and greatest and all the bling with my RTR.
Jerm13 is offline
  #26830
Wildcat1971's Avatar
I have like 5 low profile wings I need to use up, lol. they need to die fast to I cant get a high profile
Wildcat1971 is offline
Old 01-03-2013 | 07:30 PM
  #26831
you should definitely have limiters in there 3 front and 2 rear is the norm.
Old 01-03-2013 | 07:31 PM
  #26832
Jerm13's Avatar
Always the hardest thing to find is traction. I enjoy whipping the car around and not having to worry about it sliding. I tried saucing up the tires but it was way too much even for me. Until I start pushing on power, I plan on leaving it alone.
Jerm13 is offline
Old 01-03-2013 | 07:32 PM
  #26833
DaveW's Avatar
Where do you race? DRCW?
DaveW is offline
Old 01-03-2013 | 07:34 PM
  #26834
Jerm13's Avatar
I might install some this weekend and try it. Who knows. Track is smooth enough I guess I dont need that much travel.
Jerm13 is offline
Old 01-03-2013 | 08:09 PM
  #26835
Kellen Guthrie's Avatar
Front
Rear
Well first off if you want to stop doing wheelies then loosen the slipper.
Your setup seems very soft for a high bite track. Normally when you go to slicks you want to stiffen things up. Running the inside hole on the front arm will give you a longer lever arm since there is a greater distance from the wheel to the bottom of the shock... making the front feel softer. Your link seems fine in the front but i'd try number 2 pistons MAYBE number 3 if the track has that much bite.
As far as the rear goes it seems a little bit soft as well. Your shock position seems fine but 30 weight with a number 1 piston seems a bit soft. Also the rear link seems WAYY too long. If you shorten it up you'll gain a lot more steering especially on entry and you wont have so much body roll throughout the corner.
Finally adding limiters all around will give you a more stable car on entry and a more aggressive car on exit.
Hope this helps.
Kellen Guthrie is offline
