RC10B4.1 FT/WC
Old 08-25-2012 | 12:05 PM
  #19321
Lonestar's Avatar
Originally Posted by CHIZZLE
Why? .
because the instructions say so
Lonestar is offline
Old 08-25-2012 | 12:45 PM
  #19322
brent701's Avatar
No it doesn't
Says nothing about what side which outdrive goes on.
brent701 is offline
Old 08-25-2012 | 02:14 PM
  #19323
ryanpatrickgore's Avatar
How about the exploded view? Maybe there?
ryanpatrickgore is offline
Old 08-25-2012 | 02:21 PM
  #19324
Eli's Avatar
Eli
Were still talking about the diff nut and screw lol. If it makes a difference then how come oher manufacturers have it on the other side? Most importantly is to get the nut in the proper outdrive imo.
Eli is offline
Old 08-25-2012 | 02:42 PM
  #19325
Matt Trimmings's Avatar
Exactly, goes back to the "as long as its built correctly".
Matt Trimmings is offline
Old 08-25-2012 | 07:20 PM
  #19326
Rob Phillips's Avatar
Originally Posted by DesertRat
I did break it in, and it works great. No reason to take it apart just to switch to black grease in the thrust bearing.
Well, when you rebuild (which will probably be soon), use the black grease for the thrust. The silicon grease actually is designed to give the balls "grip", not just to lubricate. The black stuff is grease, and is designed to lubricate, which is what the thrust bearing needs.
Rob Phillips is offline
Old 08-25-2012 | 07:28 PM
  #19327
bds81175's Avatar
Moderator
I would imagine that the majority of the time someone's diff starts to loosen up its because the diff nut is starting to wear out. My kids T4 loosened on its own once and you could feel the difference between his diff nut and any others.
bds81175 is offline
Old 08-25-2012 | 09:32 PM
  #19328
big bore shocks buy them when released or will associated release a buggy with the big bore shocks?
SHAUN GRIDER is offline
Old 08-25-2012 | 09:38 PM
  #19329
Originally Posted by brent701
No it doesn't
If I'm not mistaken, the B4.1 Manual which is the same as the manual online does not show you which way to install the shaft, but the Worlds Manual does. Unfortunately the Worlds Manual is not available online and I lost mine, so I can't confirm.
I believe the Worlds Manual shows the shaft (The allen wrench side) installed on the same side as the slipper.
zipperfoot is offline
Old 08-25-2012 | 09:40 PM
  #19330
you should have the allen screw side on the side of the motor plate
Old 08-25-2012 | 09:46 PM
  #19331
CHIZZLE's Avatar
Why?
CHIZZLE is offline
Old 08-25-2012 | 09:49 PM
  #19332
Why?
Because he said so...
Old 08-25-2012 | 09:52 PM
  #19333
idrummerboy13's Avatar
WHO CARES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WE GET IT!
idrummerboy13 is offline
Old 08-25-2012 | 09:56 PM
  #19334
Wild Cherry's Avatar
Tech Legend
Default PINK BULL DOG Terrorizes Race Track
O-Man !
I just made me B4 way faster .....
Got two new Reedy Wolf packs & a Sonic 7.5 ....
Wild Cherry is offline
Old 08-25-2012 | 09:58 PM
  #19335
Suspended
Originally Posted by Wild Cherry
O-Man !
Now you just need a driver to wheel it
PFKAOG is offline
