RC10B4.1 FT/WC
It should be the same, it is the same trans as a ball diff. Try cleaning / replacing the other gears. It should drop right in.
Cleaned the gears out with a toothpick, super smooth now. Thanks for the reassurance!!
http://www.integy.com/st_prod.html?p...8#.UNd4nIWm6y0
It isn't light, but it is tough.
If you stay off your roof the wings last a looooong time
Anybody ever actually use that integy wing?
Tech Legend
looking to join the club here. Picked up a B4.1 with a variety of worlds parts, as well as some kyosho velvet big bore shocks.
Planning to run this indoor carpet.
Few questions if you guys don't mind:
- What is a good starting setup to go with including tires?
- Any issues people have with running shorties or do people just run standard packs?
- Is the whole locked steering rack (avid, etc) still the hot ticket?
thanks before hand.
thanks before hand.
Ouch! I'm going to do the same thing..... and I too was under the assumption they'd swamp with out issue.......
Tech Legend
I have heard that there was a change in the housing in the sc10. Is this a b4.1 or worlds version you are doing this with?
Cain, avid rack or superglue the stocker is the hot ticket still.
I bet carpet will be different than clay with this car, I know petitrc has a few carpet setups on the site. Maybe give one of those a shot?
Probably end up with the 3.5 block or 4.0 rather than the 3.0 that is commonly used on clay.
Tech Legend
you guys end up with more toe in on carpet? I'll give Petitrc a look, thanks for the heads up.
I tried looking through the thread under search but I'm now running the big bores and was wondering if I should keep the losi springs since i have all the colors I was running before with the v2's .was using red fronts white rears .or should I change to a different color
It is best to leave the setup advice to those of us that know what we are talking about.
I've got an SC10RS RTR
Also a B4.1 Worlds (kit)
Also a B4 kit that supposedly was upgraded to the B4.1 Worlds (but I don't know enough to say that for a fact)
Mission: to be sure all 3 RCs have ball diffs.
I bought an extra tranny that I know has a ball diff but needs to be rebuilt and was going to put it into one of the three that has a gear diff.... which one? dunno that part yet.
Help with setting up front end:
I'm rebuilding a used B4.1 Worlds. Both the front tires are pigeon-toed. I don't think this is right, so, which of the turnbuckles do I adjust in order to bring them in line?
Also, should I have any toe-in or camber?
Help is needed right away 'coz I'm going to be running tomorrow (first time)
