RC10B4.1 FT/WC
Old 09-09-2012 | 04:43 PM
  #20101
Originally Posted by UN4RACING
Toss those inserts in the trash, and get some AKA reds for the front and rear. You will be happy you did. I bet there is no one on here running stock inserts.??????
Losi 4wheel front stock foam the whole thing and it's dialed!
Gitsum is offline
Old 09-09-2012 | 04:47 PM
  #20102
UN4RACING's Avatar
Originally Posted by gamedog1966
Not true a decent amount of the fast guys at my track run rrear stocks in the front with the same success and at a cheaper price than closed cell foams
Fast guys go cheap! Okay I guess I lost this bet.... Wutt I owe ya..
UN4RACING is offline
Old 09-09-2012 | 04:48 PM
  #20103
UN4RACING's Avatar
No! AKA...
Old 09-09-2012 | 04:51 PM
  #20104
UN4RACING's Avatar
Originally Posted by smittyusmc
Do not run the aka foams they are way to stiff. The stock proline foams are not bad if I was you I would go with the proline closed cell hey are a good medium between the aka and stock. Thats just my two penny's
Tried them with no luck. They worked great for a night or 2. The AKA will last me 2 sets of tires. Red soft are what I use.
Old 09-09-2012 | 06:00 PM
  #20105
Suspended
To all of you arguing about front inserts.
Is it that hard to comprehend that different inserts work best for different tracks? High bite tracks will require an insert that is more firm. Lower bite tracks will require a softer insert. Think of it like air pressure in a real car tire. On pavement (high bite) you want more air pressure than if you were driving in sand (low bite, soft inserts). Remember, different tracks require different combinations to get the most out of your car. Why do you think there are so many tread patterns, rubber compounds, and inserts?
R.Shackleford is offline
Old 09-09-2012 | 06:11 PM
  #20106
Wildcat1971's Avatar
Originally Posted by Sylvain
I really love my buggy too, just looking to add another truck to the collection
Plus, we run on 1/8th scale tracks, not the best for 2wd buggies
same, I love my buggy. SC is ok if there is no wind. But i will be dusting off the T4 and running it on out local 8th scale track.
Wildcat1971 is offline
Old 09-09-2012 | 06:32 PM
  #20107
STLNLST's Avatar
Couldn't have said it better myself.
STLNLST is offline
Old 09-09-2012 | 06:50 PM
  #20108
I run the stock inserts on my JC tires. they are fine for my track.
Old 09-09-2012 | 06:55 PM
  #20109
UN4RACING's Avatar
Its not an argument but great you ruined it for us all now. We will from now on have to get the low down on track size dirt compound and dirt temp wet dry dusty sandy clay black dirt and on and on.
And we will still not be able to help one soul. And not only that we don't know how one person drives what there set up is and if they even know how to put holes in the tire or wheel one or both. Uhg!
To bad...... I guess from now on I will just say walk up to the fastest racer at the track and run what he runs.....
Old 09-09-2012 | 07:02 PM
  #20110
gamedog1966's Avatar
Hahaha, nothing bro mayb if I can get faster in my buggy I would feel a lot better, I'm pretty fast in my sc10 wher my lap times are faster in that than the b4.1, crazy huh?
gamedog1966 is offline
Old 09-09-2012 | 07:04 PM
  #20111
UN4RACING's Avatar
At our track the stock work but with the JC Ripps and that's it. Super soft. I prefer the form fit of the optional inserts over the stock ones. But thanks for rubbing that in......
http://www.jconcepts.net/store/index...roducts_id=465
  #20112
keidel's Avatar
Default Team orion carbon pro
I know the preferred battery is a shorty pack butt.. I have two different Team Orion carbon pro batteries I wanted to use for stock class. They are really tight under carbon strap bends the hold down. I also have a couple reedy batteries that are same height. Is there a different battery hold down or does nobody use these two batteries.My Gens ace fits fine butt would rather use these other packs.
keidel is offline
Old 09-09-2012 | 07:11 PM
  #20113
are you running the 4.1 stock tower or the carbon tower? some batteries wont fit under the carbon tower, because it was not upgraded for lipos. if your talking about the front thump/twist screws. all batteries are not the same height. some have thicker cases, some of the higher mah packs are a little taller. if you want to run your carbons, adjust the twist screws for the carbons and run those.
Old 09-09-2012 | 07:16 PM
  #20114
UN4RACING's Avatar
No help but I see you have a B44.1. I am running my reedy 5200 saddles in my B4.1. Makes it cheaper and easier to run both kits. And it gives more weight transfer options. Just thought I would mention it.
Old 09-09-2012 | 07:23 PM
  #20115
keidel's Avatar
I switched to the graphite tower after I broke the stock one. Yes its tight under the tower. I see about adjusting thumb screws it was under the tower where the problem is. So all I need to do is go back to the other tower? Thanks for the help. At least I got the thread off the tire talk. lol
keidel is offline
