Kyosho Ultima SC-R Thread
#4771
Trader Rating: 89 (100%+)
#4772
NewB question about gearing for these trucks. I am just finishing building a SCR-SP roller I bought off here. I have both a 78 and 82 main gear. I am running new Tekin Gen2 17.5 Motor and will be running in Blinky mode and Tekin Gen2 Rs ESC.
Question:
I have no idea what pinion or main gear to run. I want to buy a few sizes of pinion gears so I can switch up. Mainly going to run indoor LSR in Sacramento and indoor AMain Hobbies track. Can someone give me the best starting setup and then how many up and down from that setup of pinion gears I should get?
Thank you
Question:
Thank you
#4776
Moderator
Trader Rating: 470 (100%+)
Pretty sure the scr arms are actually shorter. They will fit but will affect your width.
#4779
Moderator
I have both but won't be home until 8pm EST. Will check in later.
#4781
Moderator
Ultima SC arms on left(shorter) and Rt5 arms on right.
#4783
Hello guys...i'm thinking about getting this truck(SCR) and getting in to 2wd racing. What would be a good price for a used roller?
What would be a good set up for electronic combo for a stock class?
Thanks for your help.
#4784
Depends on condition and upgrades. Is there an indoor track around you? Coyote hobbies? Pm me if you would like to see an scr-sp
#4785
