Kyosho Ultima SC-R Thread
#4741
Gearing suggestions
I have an 8.5 and a 13.5 for my SC-R and was wondering what a good gearing combo would be for the two motors. It is ran in a large, indoor track so ambient temperature is not a problem and as it is geared now, I am pulling it off at 135 or less, so can definitely gear up for some higher speed. Any suggestions?
#4742
#4744
spur gear stripping off...
yea I have the t-bone bumper and love it helps keep wind from under the body, but I wanting to know is how do I keep from stripping spur gears out, I run a orion 8.5 and got 22 pinion and 82 spur but this truck is hooked up and its rolling my pinion also, do they make a metal spur that may fit this truck?
#4745
#4746
You are doing something wrong. I would strongly suggest getting advise from an experienced driver to show you how to properly adjust your gear mesh. Also be sure you have a nice wrench like the MIP allen wrenches so you are sure you are setting the motor screws tight enough so the motor doesnt move while driving. You could possibly have a bent top shaft and that could be causing a bad mesh.
#4747
make sure your tranny screw are not going to the back of the slipper plate..
#4748
Hi guys, do you know if it's ok to run a HW XERUN 2.1 120A in mod? With 7.5T motor? Thanks,
#4749
