Kyosho Ultima SC-R Thread
#4651
R/C Tech Elite Member
I've been out too the hobby for a while and am putting the finishing touches on my SCR and have a quick question about placement of the antenna for the 2.4 Ghz receiver. Can you keep the antenna of the receiver under the body? I would rather not put another hole in the body. Could I just shorten the antenna tube (leaving the antenna itself its original length of course) so it doesn't stick out of the body without negatively effecting signal strength?
I'm using a Futaba R2104GF receiver.
I want to get this sucker done so I can race it for the first time.
#4655
http://www.absolutehobbyz.com/produc...oducts_id=8831
These are for the BB 12.0mm Kyosho shocks. 4 hole x 1.3mm dia tapered piston. Drop your oil 2.5 to 5 from what you run the stock 5 hole. Most people love them. Team AE also makes a 12.0mm tapered piston that costs less, but I have not tried them.
#4656
Just posted my Kyosho SC-R SP roller, NIP parts and mounted tires in the for sale thread if anyone is interested. Great shape and upgrades.
#4657
Where can I find a replacement rear shock absorber for kyosho ultima sc ?
#4658
#4661
Anyway to tell what springs I have on my new to me SC-R? I have the regular bore velvet shocks but I'm not sure on the springs. I thought I read somewhere in this thread that they are etched on the spring but I can't find any marks on the springs, they are simply black in color all around.
#4663
your going to want to run 75 front and 70 rear.
#4665
take a close look, hold it so you are looking directly at the end, you can see the area they ground down to flatten the last spring coil, the printing is right next to that on the unflattened part of the last coil. It's small and printed in a gray color. The spring itself is not painted.
